So i used Swirl X and....
  • #16
    Re: So i used Swirl X and....
    oh ok yeah i worked for maybe 30 sec but it becomes very grabby and starts to be difficult to work with. its also some what hard to remove from the bottle. so i should work in small spots and do it for 2-3 min?
    Click For My Main Youtube Channel
    Click For My Meguiars Review Channel
    ^^Meguiar's Review Specialist^^
    • #17
      30 seconds isn't really sufficient to get results out of the product. If the ambient temperature is low, or the surface temp of the car is low (and we have to figure this is probably happening to you given your location and the time of year) you may run into some issues that prevent proper use of the product. Make sure you have sufficient product on your pad, too. Shoot for at least a full 1" diameter blob of product on the pad to cover a 1' square area. Just a couple drops is not enough product and you'll get a very short working cycle with that.
      But really, if it's cold out, you just aren't going to get a valid experience with the product.
      • #18
        ok. well i will try to use it when it warms up. because it was very hard to work with at about 10* so. i will try again in the spring. i worked it in more in my hood but it took some out but not enough. but ok i will wait until its warm and my car is warm
