haze on back window
  • haze on back window
    in the daytime the back window looks clean and perfectly clear, but when its night time and when a car is behind me with its lights on the back window looks foggy, the first time i saw it i thought it needed to be defogged so i put the defogger on but nothing, as soon as a car is not behind me i can see out of the window perfectly but when a car is close to mine with its headlights on the haze becomes visible, ive tried eagle one 20/20 glass cleaner on the inside and out and even after washing the car the haze is still there when a car is behind me with its headlights on, but it is only visible at night during the day when the sun is behind me the haze is not visible, any suggestions??
    Re: haze on back window
    Sounds like a pretty good film on the inside back window.
    Of course you will be told to try Nxt Glass Cleaner.... But yeah, I would be trying to clean it a few more times. Good glass cleaner, good MF towel.
      do u think the film must be from rainx anti fog stuff i put on the back window awhile ago
        Well, I have a feeling the anti-fog stuff would be something oily... and stuff sticks to oil.
        Could be why it would take a few times to get off.
        Maybe try giving it a real heavy cleaning, like lots of glass cleaner, probably will streak, but really get cleaner on there. Then you can always come back for a regular cleaning after.
          i had this problem too when i used stoners invisible glass...my windows always hazed..but i thouht cuz it was cold...but i switched to meguiars quik glass and it dont happen anymore
          Don't get so caught up making a living that you forget to make a life.
            should i scrub the glass hard or gently and should i use a microfiber or paper towel
              I prefer MF..
              Dont want to rub too hard, or use anything too strong because of the defroster elements, etc.
                A cleaner like Ultimate Compound works really well on glass and often will remove more stubborn issues than a simple glass cleaner will.
                *Warning - Only use a paint cleaner if the window in question
                is bare glass. If you are dealing with a tinted window that
                has tint film or defroster elements on top of the glass
                you will not want to use a paint cleaner. Also, be careful not
                to get product on the surrounding trim/moldings.
                Brian Hann
                Manager - Meguiar's Solutions Hub
                Irvine, California
                bhann@meguiars.com
                (800) 854-8073 *3870
                  its my back window, it is tinted and has the defroster elements so i wont be using a paint cleaner, is there any stores that carry nxt glass cleaner besides online?
                    I was afraid with a back window that would be the case. Well, someday you will have a situation on another window that a paint cleaner will help with!
                    Our NXT Glass Cleaner is not carried at any large chain retailers or auto parts stores. Your best bet is to get in online.
                    Brian Hann
                    Irvine, California
                    bhann@meguiars.com
                      Terry cloths and a good quality glass cleaner should serve you well.
                      If you cannot find a good quality glass cleaner, use some soft water.
                      Glass cleaning does require a bit of technique.
                        i have eagle one 20/20 glass cleaner
