How important is using polish for keeping paint from drying out? I'm wondering in the conext of using a sealant that does not contain polish itself.
how important is polish for hydration?
Re: how important is polish for hydration?
On a new car, not as much.
Older single stage paints absorbed much more polishing oils (and similarly lose oils). The new clear-coat paints, and even new single stage ones, wont absorb as much.
And paint will absorb more as it ages, less when new.
So a brand new clear-coat will not absorb too much at all. And since the cleaners, cleaner/waxes, waxes, (at least from Meguiars) all seem to contain a little bit, you would certainly be fine for a new car.2017 Subaru WRX Premium - WR Blue
It has to do with the pores of the paint. As paint ages, its pores grow larger and larger allowing more oils to be absorbed into the paint.
Older clears will benefit from a pure polish but as Murr said, not as much as older single stage paints.Tedrow's Detailing
845-642-1698
polish brings out the paints beauty. it will defenitly help your paintClick For My Main Youtube Channel
Click For My Meguiars Review Channel
^^Meguiar's Review Specialist^^
Most modern automotive paints are water-based and the resin binder system no longer requires oils to help the paints elasticity the way they were with Nitrocellulose Lacquer.
The oils used in polishes and compounds are used to provide surface lubrication
The oils used in Carnauba waxes will provide jetting (the so-called wet look), oils on a paint surface will negatively affect the bonding and therefore the durability of a polymer sealant. This is one of the reasons foe using the wipe-down process~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ Blog – http://togwt1980.blogspot.com
Originally posted by therdrman View Postpolish brings out the paints beauty. it will defenitly help your paint
Using a polish by hand will correct very little, mostly just cleansing the surface.
Hitting the paint with a rotary and the correct or even numerous grades of polish will bring out the paints beauty. Depending on how bad the paint is you may have to wet sand the paint and then use a number of grades of polish, reducing in aggressiveness to fully bring out the paints beauty.
Originally posted by TOGWT View PostMost modern automotive paints are water-based and the resin binder system no longer requires oils to help the paints elasticity the way they were with Nitrocellulose Lacquer.
However I think there are a few instances where the paint is somewhat confusing. For instance generally german paint is very hard and will absorb nothing and looks good for years after it's been fully corrected. On the flip side Honda or generally japanese paint is very soft. I've seen the paint on these cars looking disgusting after (for instance) 6 months on from a full correction.
When going over with a swirl spotter there are no real swirls or defects to write home about, but the paint has gone from white to a milky off white. When examined further the paint appears to have absorbed grime over those months despite being waxed or sealed using good quality products.
The only way I've seen to correct this is to hit it with a deep cleanser/finishing polish.
Just to chime in....
Products like M05, M07, M45, M81, etc will have greater impact on older single stage paints where the oils in these products can nourish the paint.
However, on modern clear coats, the products oils do not enter the pores, but instead fill in the micro-fissures on the surface of the paint, thereby creating a smoother and *perhaps* a more reflective finish. I say perhaps as with proper compounding, polishing and finishing steps, it is unlikely you would see that dramatic of a difference on most clear coats.
