#9 and #82 sound like they do the same thing with the same aggresivness rating on the front of the bottle. What's the difference? I plan on using #9 on my truck but wondered what the difference is???
Originally posted by racer742 #9 and #82 sound like they do the same thing with the same aggressiveness rating on the front of the bottle. What's the difference? I plan on using #9 on my truck but wondered what the difference is???
Adam
#82 Swirl Free Polish offers a tad more cleaning ability than the #9 Swirl Remover 2.0 Most people wouldn't notice a difference.
If you do a search there are a lot of discussions on this question.
Does #82 have more polish in it than #9 or are they the same except for cleaning ability. SO basically is #82 more of a cleaner polish where as #9 is a cleaner that should be followed up by a polish??
I did a small test of #9 on a friends car. He used a rubbing compound to remove a scratch. Well the compound left a dull trail behind. I used MPPC, #9, and #83 if I recall. This was before I purchased #80 or #82. MPPC did a slightly better job than #9 of removing the marring (I was shocked). The #9 did do some work to remove the marring. I used 50/50 alcohol and water to remove any oils left behind to check my work. The marring was reduced but would require several passes. Now for the #83, it was a workhorse. In 2 passes the marring was virtually gone. I again did the 50/50 check of my work and yep the marring was gone. I even got down to some of the scratch.
My point is #9 will do some swirl removal. Maybe not as quickly as I wanted.
I have yet to compare #9 vs #82. I really stopped using them both after buying #80.
Originally posted by racer742 Does #82 have more polish in it than #9 or are they the same except for cleaning ability. So basically is #82 more of a cleaner polish where as #9 is a cleaner that should be followed up by a polish??
Adam
#82 has more cleaning ability than #9
They are both cleaner/polishes and after using them you have the option of using a pure polish, or go straight to wax.
Shouldnt I try the least aggresive first and if that doesnt do it, then move up or are #9 and #82 so close it really wouldnt matter? The paint is in real good condition, 2004 silverado I bought right after Thanksgiving, always washed with GC and waxed twice with NXT.
I think I'm going to use #9, which was my original Idea, Mike says that #82 has a tad bit more cleaning power(swirl remover) than #9. My truck finish isn't bad by anymeans, I just want it to be as best as possible, lots of shine, protection, gloss, you know look amazing.
If a dark color then #9 would give nice depth and gloss.
When I bought my new black truck it had minor swirls (cob webs) and I used #80 right off the showroom floor. I had a specific problem I was trying to fix.
