water magnet wash b4 use?
  • therdrman
    replied
    Re: water magnet wash b4 use?
  • therdrman
    replied
    thanks man
  • cnfowler
    replied
    This is how you do it.
    1. Place items in washer
    2. Add detergent
    3. Turn machine on
    Washing machines follow this order - they wash, the water drains, it refills with water (this is the rinse cycle), it agitates, it drains, it spins.
    4. During the rinse cycle (after it drains the soapy water and fills with clean water), add the 1/2 to 1 cup of distilled white vinegar. Just pour it in. Don't worry about putting in anywhere special.
    Vinegar has long been used as a natural fabric softener. It helps strip the residue build up of soap, oil, etc. This is what gives fabrics their soft feel. It also allows the Water Magnet to absorb water. Overtime, buildup on the fibers of the Water Magnet prevents it from absorbing water. It will actually just smear the water around the car. We use vinegar because it rinses clean and doesn't leave anything behind on the fibers. Your items won't smell like vinegar when you are done, unless you use too much. Even then, they won't smell like you're sniffing the vinegar bottle. It will be faint, but it won't affect anything.
    Colin
  • therdrman
    replied
    oh ok i see. ehy what does teh final rinse mean. i havent done much laundry before? i would usualy just put my detergent and the vinigar in b4 i start the wasing machine will that work?
  • Michael Stoops
    replied
    Put the vinegar in the final rinse. If the washing machine has a fabric softener dispenser that would dump fabric softener into the rinse cycle you can use that for the vinegar - it will only dispense what's put into it. Of course, if there as any fabric softener left behind from a previous use that might be an issue. Personally, when I do use vinegar I just pour it in during the final rinse.
  • therdrman
    replied
    ok. hey micheal so i add the vinegar with teh detergent right on top of teh cloths? im kinda confused. or do i place vinigar in the fabric softner holder./ but wont that put fabric softerner in it? and also can the applicator pads be vinigared?
  • Michael Stoops
    replied
    Originally posted by therdrman View Post
    can meguiars wash mitt be washed with other microfibers?
    It can, and should, after every use.
  • therdrman
    replied
  • therdrman
    replied
    oh ok. well i think i will wash the applicators by hand. with some detergent and use a bucket of water. the water magnet i will probably ash after the 2-3 use same with the microfibers and i will add 1/4 vinigar. then when there done washing. i should re run the cycle.? (do i add soap again) becuase my Mom doesnt want me washing 4-5 things. so often.
  • Michael Stoops
    replied
    It is a good idea to wash your microfibers, whether Water Magnets, Supreme Shines, etc prior to first use. All they really need is a quick, light wash and dry for that first go.
    Subsequently, you should wash and dry all microfiber towels and applicators after every use. This includes Water Magnets and wash mitts as well. Warm wash, cold rinse, liquid detergent (amount as recommended by detergent manufacturer and/or washing machine maker) then a low heat tumble dry. Low enough heat that if you have to run them through twice, so be it.
    From time to time a half cup to a full cup of distilled white vinegar in the rinse cycle can do wonders for that final breakdown of anything left in the material of the towels.
  • J. A. Michaels
    replied
    Depending on the size of the load. I use anywhere from a 1/4 to 1/2 cup of vinegar. After the wash cycle is complete. Run the rinse cycle a second time. This rejuvenates the microfibers. The towels work great after this trick.
  • therdrman
    replied
    anyways ill have to check back later
  • therdrman
    replied
    well i ahve a thing in my washer for fabric sofenner. now i think i will put just say 4 teaspoons on vinigar in the drum along with 4 teaspoons of detergent in the drum. with the cloths and wash it that way will that work?
  • wifpd4
    replied
    i treid nothing on google. can you tell me step by step what you do. i mean i put laundry soap in. then where the fabric softer thing is do i put vinigar in there. or put it right on top of the water magnet or microfiber? explain? no one has actually said step 1.... kinda thing
    I sort my microfibers by colors. White, Yellow, Orange together and another load of Blue, Green and Brown. Lights and darks separate. Some colors bleed; not sure it matters, but each color has special uses in my work flow.
    Next I inspect each towel before I put it in the machine. A dirty spot gets a shot of liquid oxy-clean spray.
    Our high efficiency washer has a place for liquid soap, following soap manufacturers instructions I use the appropriate amount of soap. Then I fill the rinse aid receptacle with vinegar. Set the controls to warm wash, cold rinse and single spin. Water level based on quantity of towels.
    When done throw in dryer on medium heat, fold neatly when done. I store them in cloth grocery bags with cheap terry cloth towels on top for dust protection.
    Other experts may have better procedures.
    http://www.meguiarsonline.com/forums...ad.php?t=29385
    http://www.autogeek.net/mi101.html
    http://forums.focaljet.com/focus-det...er-towels.html
  • therdrman
    replied
    i just need to know like how much vinegar. do i put right on the cloths? how much vinegar to soap ratio that kinda thing then after do i hang to dry. is it better to wash with vinigar by hand you think? are we talking droplets of vinigar
