Should I use the UC or M205 with DA polisher?...I am going to clay to remove contaminants first.
Detailing with minor paint defects
Re: Detailing with minor paint defects
Since we can't see the car there is no way to recommend a specific product to use. Hardness of paint, level of defects, desired result, skill level of operator - these all play a role in the final outcome of the project.
If you have never worked on this particular vehicle, definitely do a test spot with the less aggressive of the products you have on hand and see what that tells you. If it takes care of the defects then you know you're good to go - if not, you may need to give a second pass of the same product/process, take a more aggressive approach with the same product, or step up to a more aggressive product.Michael Stoops
