Whats after the UC?
  • Whats after the UC?
    I have used the Meguiars Ultimate Compound along with my gl110v2 to get rid of 90% of the swirls on my black 2006 350z. However, there are still some swirls that just won't lift out. What is the next product I should use to take them out? The UC just isn't cutting it and I don't know what to use next. Thanks in advance!
    If you live around Charlotte, NC and would like your car detailed, PM me.
    Re: Whats after the UC?
    How many passes of UC did it take to remove 90% of the swirls?
    If only 1-2 passes of UC (assuming Megs yellow pad & speed setting 5), you can probably remove the remaining 10% with another 1-2 applications.
    If you already have 3-4 passes of UC - may need to use 105 the remove the remaining swirls. NOTE: if you use 105, may need to follow-up with UC or 205 to remove slight hazing).
    Also want to consider the effort to remove the remaining 10% of swirls may take another 75% in effort (i.e. can you live with 90% reduction in swirls).
    Andy W.
    Bimmers - '72 Tii, '74 Tii, '88 M3, '91 318is, & '01 330i
    Ford - '91 Ranger
      Yeah, #105 would be next, but your technique alone may cover the last 10%.
      Also, being sure they are the same swirls/scratches, and that you aren't causing marring from using a strong product.
        I have done two passes with the ultimate compound. I am using the megs yellow pad and speed setting 4-5. Ill take another pass or two on it and update with what I get. Thanks!
          You'll be fine with 2 more passes .. problem solved.
          Let us know!
            Hey guys, its been a while but I finally got the time to do another pass with the UC. Let me just say thanks! I was at speed 5 applying light pressure and actually removed all visible swirls from my black 350z. Honestly, I can't thank you guys enough for recommending me another pass, it really solved my problems and fix my crazy OCD with these swirl marks Now I just need to find a way to boost the shine and deepness of the black on the car besides waxing it every three weeks with NTX 2.0 Any suggestions? I use the Quik wax a fair amount, but I feel like there is something else I can be doing to increase the shine on it. Thanks!
              Well, you can look at things like #205 as a finer cleaner next time. Following up with a pure polish may help. Then waxing.
              You are using the UQW or the QW?
                Glad to hear you were able to remove the remaining swirls with additional passes of UC.
                If you want to boost the shine & depth - try applying a polish like M7 or Deep Crystal Polish prior to NXT.
                I've also heard people applying Gold Class Wax or #26 on top of NXT to increase "depth"
                Andy W.
                Ford - '91 Ranger
                  I'm using the UQW.
                    I actually use to use gold class, but believe NTX gives it just as good of a look, along with a lot more protection. I actually applied gold class after NTX a few weeks ago but didn't believe it made too big of a difference compared to just the NTX alone.
                      You wont need UC of course now, so I think #205 will help a good bit.
                        Recently did my wifes girlfriends Z.....#80, #7, NXTv2.
                        Photobucket
                        Photobucket
                        Black......the ONLY color!
                          Kyle, you can deepen the gloss and shine by further polishing with M205. What you want to do is to level the paint surface as much as you can, thus creating a mirror-like surface. Begin with M205 and a yellow polishing pad and then follow-up with M205 and a black finishing pad. By this burnishing of the paint you will see a marked improvement in gloss, shine, and wetness.
                          Don't be shy about applying pressure. You need to apply constant and sustained pressure but just not enough to stop the pad from spinning.
                          Choice of wax is just the cherry on top. The real improvement in gloss comes through polishing.
                          --Al Kimel
                            +2. It is all about the prep work.
                              Ill have to pick up some of the #205 soon then. Just out of curiosity, do any of you guys buy it in stores? I was pretty sure it was an online only thing, but wasn't sure. Thanks!
