Ultimate compound question
  • Ultimate compound question
    Hello everyone new in this forum and also new using car care products.
    Hope you can help me I want to know if ultimate compound + G110v2 can remove 2500 or 2000 sanding marks???
    Or what product do you recomend me for this sanding marks?
    Re: Ultimate compound question
    http://meguiarsonline.com/forums/forumdisplay.php?f=150 Try this and see if it helps you any. sorry if not! There are pictures from "How To" classes and instructions that might can help ya out
      Unless you have very soft paint the chances of that combination removing your sanding marks is quite small. A rotary buffer is usually required to remove sanding marks. That said, if you're just sanding small touch up spots then it may be sufficient. But if you've just painted the whole car and then wet sanded, you'll be much, much better of using a rotary and something like M105.
        Thanks for your reply both of you.
        I am only sanding some spots, not all car.
        maybe I will do with the DA.
        So, first i can use UC, then Swirl X and then Wax ???
        Thanks again
          Yes, that should be fine.
