water spots removal
  • water spots removal
    what's the best way to remove stubborn water spots on paint?
    Re: water spots removal
    What have you done so far?
      i did a paint correction on a car and still couldnt get rid of some.
      Wash,clay,105 meg yellow pad,205 meg blk pad,sealer/glaze,wax
        Sometimes water can etch paint so badly its impossible to remove without excessively thinning the paint layer.
        Is your car the 2001 Camaro SS in Black that was at a TNOG session within the past couple of months?
        Andy W.
        Ford - '91 Ranger
          no. this was on another car i worked on.
            so there any products made for this purpose?
              Can you feel the water spots with your finger nails? If yes, the water etching may be too deep to safely correct.
              Did multiple passes of 105 on a yellow pad with a DA gradually reduce the water spots?
              - if not, then you may need to switch to a Rotary
              Andy W.
              Ford - '91 Ranger
                cant feel them.
                  Andy is spot on (no pun intended) with this, as usual. Water spots can get etched pretty deeply into the paint and when/if they do then they can be a real bugger to get out. Paint hardness plays a huge roll in this as well.
                  Did you make any progress at all on them? What kind of car are you working on? Color? We've seen cases where even M105 on a wool pad via rotary struggled to fully remove water spots, so they can be very challenging in worst case scenarios.
