My 1st time
    Re: My 1st time
    What is the difference between glaze and polish, the NXT I mentioned above is not a glaze or is it. On a White car what would give it the best wet look I will be yellow waxing last , what should go right before the final wax.
      Re: My 1st time
      Many times "polishes" have very very tiny amounts of abrasives along with polishing oils. A glaze is basically a pure polish. It is 100% polishing oil that is made to nourish the paint. It is also able to hide light defects.
      No, NXT is not a glaze or polish. It is a wax.
      A glaze is an excellent choice to use before wax.
      ChrisThompsonsCustom@gmail.com
      www.ChrisThompsonsCustom.webs.com
      (352) 897-0050
        Re: My 1st time
        OK NXT goes back to store, I want to use the yellow #26 paste even though I am not sure which will give me a richer glossy shine with my white car.. What glaze can I use with the #26 paste wax, so glaze works with any wax.
        Just to clear this up 1- wash, 2 clay, 3- wax cleaner, 4 -glaze ,5-wax
        On a new car that dont have many swirls from what I can see right now should I use the wax cleaner only where I see any swirls after claying. What would be best swirl remover for a new car as your oppinion. OK I know I am almost getting this.
        I
        you guys for getting me through this. I always dreamed of an M3 and just want to get this right. I can't mess up a 80 k car I would be heart broken and have a bigger problem with my wife. I will say 1 thing for sure there are some very helpful caring people on this site. The BMW M3 forums were awesome also.
          Re: My 1st time
          Best thing for removing swirls on a new car would likely be SwirlX unless the swirls are real bad. You might want to take a look at this article as well.
          -HealthyCivic
          Check out the glossary
          • #20
            Re: My 1st time
            Guys I gonna give it a wirl not a swirl today. I will wash and dry car carefully with Megs shampoo, I will then will use Megs QD spray-clay kit. If I see no swirls in the car like I did not before the ones I put in it real light. I will use Megs color x in those 2 spots I see without doing whole car. Then I will go to glaze car with Megs #7 i think wife just got me then go right to Megs #26 solid paste. Do you think I am missing anything,could it be I dont do a cleaner wax, How many waxes can I put on this car brand new,glaze, paste #26, a cleaner wax would be overkill as a trird wax before the other 2 processes
            • #21
              Re: My 1st time
              Choose a cleaner wax and then put a wax after that. I wouldn't do 3 different waxes on the car, there's not much point. And don't do #7, #26, and then cleaner wax because then you'll remove #26 and #7. Basically, do not use anything with "cleaner" in it after you put a coat of wax on.
              -HealthyCivic
              • #22
                Re: My 1st time
                Can I put #7 glaze on car for tonight and then put the #26 paste on tomorrow I wont have the time to do both tonight.
                • #23
                  Re: My 1st time
                  Sure.
                  Just QD tomorrow first if needed, gets dirt/dusty.
