I have a similar problem to this guy here with my CL9/TSX. I just hope the problem is external, not internal
Friend told me it's a common problem with CL9 with HIDs
I bought the wetsand 1200 grit and ready to sand it down.. but what products can I use to polish/buff it to remove the scratches from wetsand??
Would scratchx be fine on plastic material ? Plastx ?
Some guy on aanother forum recommended wetsand > polish/buff to permanently fix it.. And plastx is just a "temporary" fix
Any help would be grateful so I won't do any permanent damage to my headlights! lol
Update after work progress.....
I just sanded down with 1200 grit paper... wiped down clean... then polished/buffed with plastx... did the whole process for about 45mins
It's better now... removed the imperfection residue or whatever
But now i have a 2nd problem..
My right headlight is slightly cloudier than my left headlight and the fine scratches are visible.. not too bad if looked from far..
What can I do to fix it now ? 2000 grit paper sanding it vertically since I sanded 1200 horizontally..? Should i use scratchx or M105 to remove the fine hairline scratches ?
Or should I be really using an electrical buffer at low speed?
