Hot Rims all wheel cleaner on painted rims?
  • Hot Rims all wheel cleaner on painted rims?
    will this ruin my paint and dissolve it if it is on for 15 seconds on a cool wheel becuase the paint is out of a spray can. what should i do?
    Click For My Main Youtube Channel
    Click For My Meguiars Review Channel
    ^^Meguiar's Review Specialist^^
    Re: Hot Rims all wheel cleaner on painted rims?
    does anyone know i need to know asap
      Clearcoat is paint without pigment. All Wheel Cleaner gets used on this all the time without issues, but at the same time this is a low pH product (~2.0) that has been known to damage paint on some disc brakes (when misused). Typically the issues I have seen with disc brakes have been when the product has been left on for a long period of time (I'm talking minutes) or when the brakes are hot.
      All I can say is do a test spot. Wet the wheel, spray the product, rinse it off right away. Increase the dwell time as you feel comfortable.
        ive just read that people say painted rims that you have done yourself stay away from all wheel cleaner and get the aluminum wheel cleaner because it is less hardcore is that true?
          All Wheel Cleaner has a pH level of 2.0 (which is acidic). Aluminum Wheel Cleaner has a pH level of 7.0 (which is balanced - water is 7.0). So yes Aluminum Wheel Cleaner is milder.
          If a balance product (like car wash soap) isn't providing enough cleaning power, then you may want to use the All Wheel Cleaner (I'd skip the Aluminum Wheel Cleaner for your application, you are not cleaning bare aluminum. It not like staining will be an issue).
          Make sure your wheels are wet and watch your dwell time. You're not working with a product that instantly eats metal and paint, let's not get carried away.
            I worked on a vehicle with painted rims 2 weeks ago. I used all wheel cleaner no problems. But instead of using a wheel brush, use a sponge or something else non abrassive. And take it easy. The guy who brought in the vehicle used a wheel brush and accidentally rubbed off the paint on one of the points.
              Nothing wrong with going to the Aluminum Wheel cleaner, or soap and water if worried.
              I dont know how spray canned wheels would compare to the factory paint.
                All Wheel Cleaner is safe and effective on all factory coated wheels. From what you're saying it sounds as though the wheels in question here have been rattle canned by you or a friend, right? If so, all bets are off and you're best to stick with either the Aluminum Wheel Cleaner or soap and water.
                  i actually decided to return the all wheel cleaner i will stick to soap and water
                    i dont know what long term effect it will have on my wheels. but i have factory painted wheels, and i used hot rims all wheel cleaner for the first time about a week or 2 ago. my wheels have never looked so good. no other wheel cleaner has given my wheels this much shine. i even got a compliment on them from a friend a few days ago.
                    2007 Toyota Tacoma Double Cab V6 SR5 - Black Sand Pearl
