What products can be used in direct sunlight?
Meguiar's and the heat
Re: Meguiar's and the heat
None are advised, but all can be used, to one degree or another. That's a real broad question given Meguiar's has about 300 products.
If you look at Tuck91's detail jobs in the Show Off Your Latest Work forum. He often works in direct sun. Washing etc. He lists all the products he uses with product links. That should give you a good start. If you have any more specific questions feel free to ask.
Here's a link to a nice black Camaro to get you started.
Sure.
Direct sunlight is not the problem, it is surface temperature. If you are able to comfortably leave your hand on the surface, then it is probably ok work on, sunlight or not.2017 Subaru WRX Premium - WR Blue
Originally posted by Murr1525 View PostSure.
Direct sunlight is not the problem, it is surface temperature. If you are able to comfortably leave your hand on the surface, then it is probably ok work on, sunlight or not.Barry
