I just need your guys input on which size should I stick to buying for a set of Surbuf R Series pads. I only have the backing place that came with my G100V2, so I was thinking of ether going with 6.5 in pads, considering that's the size of my W8006 pads I have, or should I go 5.5 since the velcro area of the backplate only seems to cover a smaller area of the pad.
Surbuf R Series Pads Sizing info
Re: Surbuf R Series Pads Sizing info
A 5.5" pad is going to be a bit of a tight fit on our W68DA backing plate. You want a little more overlap than what you would get with that combo in order to keep the edge of the backing plate from touching trim, adjacent panels, etc. Best to either go with the larger pads, or pick up a W67DA backing plate if you really want to use the smaller pads.Michael Stoops
