Re: What is the difference between Last Touch and Final Inspecton?
Thanks for the clarification, Mike.
I hope your head is fine ha..ha..
Best of class for sure
Originally posted by k3ith View PostIt's pink and if you don't have a pink car, don't use it. Who cares what color it is?
BTW I love the stuff!
Last Touch..is it orange..is it pink..is it both..is it bad photography.?
Seems Meguiar's should fix their media to show the correct color?
Originally posted by rhairman View PostMike, sorry for my confusion. On your post above, you said that "Leaving even the tiniest amount of a non body shop safe product like Ultimate Compound can and will give you problems" where on the list of 'Body Shop Safe or Not' it says that Ultimate Compund is body shop safe. So, actually is it body shop safe or not? Thanks.
Ahh, that's better.
My apologies. UC is indeed body shop safe. But it is NOT a rotary approved product. Even so, several people have reported excellent results using UC with a rotary, but such use is done at your own risk.
Originally posted by Jim Shearer View PostI tried half the car with Last Touch and the other half with Final Inspection. Strictly from a non-scientific subjective opinion, I thought Last Touch rendered a little more gloss. I definitely think the Last Touch felt slicker when doing the final wipe with a new cloth.
So Last Touch wins for me.
It's nice that you like the product that costs less
Originally posted by Bill Davidson View PostYou say you have them both. What are your impressions? It would actually be nice to know what someone with less experience with the products thinks of them.
While "body shop safe" does indeed mean the product is "paintable" that does NOT mean that you can just apply the product and not worry at all about proper surface prep before actually spraying the paint.
In a body shop environment it doesn't take much silicone at all to cause an issue with paint that is being laid down on a panel. A spray product can easily be carried by a slight breeze, causing a small amount of it to be carried onto a prepared panel. Once the paint is sprayed, even a tiny droplet of silicone will cause a fisheye in the finish. So using a sprayable product with silicone in it is a bad idea in this environment.
Liquid products run a much smaller risk of having an airborne component (unless you're not terribly efficient picking up a bead with your rotary) but it can still happen. Still, when prepping a panel for paint you always want to thoroughly wipe down the panel. But if the products you use are "body shop safe" or "paintable" and you happen to leave a little bit behind, you shouldn't run into any issues. Leaving even the tiniest amount of a non body shop safe product like Ultimate Compound can and will give you problems.
For a complete list of Meguiar's products that are body shop safe, see Body Shop Safe or Not?
Originally posted by bsibold View PostBody shop safe means that you can paint over it. No need in an IPA wipe down
Also, (again I could be wrong), it's not the silicone that is applied to the paint that is the problem as this is removed when the car is wiped with solvents... It's the fact that the silicone can land on other cars when it is misted and cause problems that way.
Originally posted by Bill Davidson View PostI think it has to do with how well it performs in direct sunlight. Typically he likes to cut Last Touch a little with water for direct sunlight situations.
If you look at the MSDS sheets
Last Touch is recommend to be used as a maintenance product, it is pH balanced 7.0
Final Inspection is recommended to be used as a cleaner and has a pH level of 8.0
There have to be more differences, than just a bit of silicone.
Last Touch has silicone in it . Final Inspection has none.
