#9 swirl remover polish
  • #9 swirl remover polish
    I bought a lot of this a while back to ensure I always had it. However, it seems in the beginning it was more gelatinous (thick) than it is now. Now it is very runny - not quite like water, but pretty runny. Does this stuff break down over time and my 'stockpile' has gone bad?
    Re: #9 swirl remover polish
    The polish is probably starting to separate, shake it up really well and then use it
      I had the same problem but I left mine in the garage over the winter so I think the cold affected it. I see you're from California so shake it up real well. You might even want to insert a small stick to see if sediment on the bottom has completely dissolved.
      BobbyG
