How much money (in product) do you use per detail?
  • How much money (in product) do you use per detail?
    So like the title says, how much do you think you spend per detail? Have you figured it out ever?
    I just added everything up that I use and it looks like for an exterior detail I'm at about 10 bucks worth of product, and this is how I got to that number
    Washing (I use about 2 oz of soap in my gun)
    Claybar (I assumed 1 car per 10gram of claybar...on average)
    Polish 1 (Usually use ~4 oz on a normal sized sportscar/small sedan)
    Polish 2 (Again, 3-4 oz on a normal sized sportscar/small sedan)
    Wax/Seal (Generally use about 1-1.5 oz when spread via PC)
    Detail Spray (Figured about 2oz per car used)
    Tire Shine/VRP Dressing (around 2-3 oz used)
    Wheel Cleaner (2-3 oz used)
    Those are the major things I use for an exterior detail...sometimes I'll hit something special, but that's what I typically use.
    I'm not factoring in wear and tear on machines, cloths, pads, etc...
    Edit- I'll add that my cost is basically halved (a little more actually) if I don't include machine polishing steps 1 and 2.
    77
    Under $10
    27.27%
    21
    $10-$15
    36.36%
    28
    $15-$20
    14.29%
    11
    Over $20
    22.08%
    17
    Shawn - Final Touch Auto Detail
    Houston Area Mobile Detailing
    www.FinalTouchAutoDetail.com
    Re: How much money (in product) do you use per detail?
    I'd say you're probably about right. Using concentrate products like the Detailer line definitely helps keep the number lower without sacrificing quality.
      Absolutely. Right now everything I have in conentrated formulas is from Chemical Guys...but I tell you now that I cannot wait until I run out to switch to the Meguiar's Detailer line. They have a lot of products I really want to get into.
      I couldn't wait with D151 though and had to buy a gallon of that a few weeks back and it has quickly become one of my favorite products
        Good poll. It will be interesting what the majority thinks they spend per detail.
          Well... being Canadian, I have to add about 50%.
          By the time I add up Body Solvent, Wheel Brightener, ASD, Hyper Dressing, Super Degreaser, APC, Polishing Compounds, Glass Cleaner, Car Wash Soap, Clay, Detailing Spray, Wax, Scouring Pad, Steel Wool, Water, Electicity, Laundry Soap.
          I'm thinking ~ $30. It depends on the condition and the size of the vehicle.
          I'm curious if anyone charges a separate fee for products used. The garages have no issue with charging for shop supplies.
            Each car is different, so its hard to say. I also don't use the same LSP's all the time, as I have several I use.
            AeroCleanse, LLC
            www.aerocleanse.com
              Wow, $30 dollars is quite a bit.
              I'd be curious to see what everyone who spends over $20 on a car uses.
              I was figuring my prices around a typical large 2-door or small-medium 4-door car.
              The only time my COST would really get much higher is if I use a boutique wax/sealant that is over $50 for 16 ounces.
                D-Line products ftw!
                  Remove swirls my friends.
                    How about how much time in labor? I know this can vary greatly by type of auto, but I am curious about how long it takes you peeps to go through all the exterior steps for an average, decent condition, auto (not counting curing time). Granted, I am novice (only done about 15 autos through the full primary process). Here is what I figure for me:
                    Average Car / Mid SUV
                    Exterior Wash & Dry - 45 min
                    Clay - 1.15 hour
                    Tape - 30 min
                    Cleaner / Swirl - 2.5 hours
                    Sealer 1st Pass - 1.15 hour
                    Sealer 2nd Pass - 45 min
                    Wax Topper - 45 min
                    Trim Detail - 45 min
                    Headlights / Taillights - 30 min
                    Wheel Detail and Tire Dressing - 40 min
                    Windows - 20 min
                    Last Touch - 20 min
                    This is about 10.5 hours and I am guessing I am slow?
                    "The Dude Abides"
                      Some of your times seem quite lengthy
                      It shouldn't take you that long to claybar a vehicle. Claying is a very quick process, typically. I can generally clay a vehicle in about 20 minutes. Much less if the only surfaces with much contaminant are the hood, roof and trunk areas.
                      Why does sealant take over an hour? I can apply it in about 10 minutes via PC.
                      What are you doing to the headlights/tail lights that wasn't covered in washing and claying? A separate polish?
                      20 minutes for windows seems quite excessive.
                      20 minutes for a quick detailer also seems excessive.
                      Time is money, but never sacrifice your quality. If you aren't comfortable moving quicker, then just do your thing and charge accordingly
                      For me, a car getting a single stage machine polish generally takes about 6.5 hours and a car getting a two step (machine compound + machine finishing polish) takes me about 8.5 hours.
                        Clay - 1.15 hour
                        Tape - 30 min
                        Wax Topper - 45 min
                        Windows - 20 min
                        Last Touch - 20 min
                        If the surface is heavily contaminated then it will take hours. I think you would agree that an overspray removal job takes at least a couple hours.
                        I sometimes spend about twenty minutes on the windows. Getting them 100% streak free and clean inside and out is not that easy. Especially on a truck.
                          Nice to hear. I don't think I have ever did a 100% perfect job on my own windows at least not all of them at one time. I try to do the windshield extremely well, but by the time I get around to all of them, good enough becomes good enough.
                          I can see how doing customers cares would be a different story. I've personally never did an interior for a customer, just exterior work (being it's a hobby for me).
                            For cars and Pickups, depending on how dirty the vehicle is, I have a built in $10. For SUVs, I again built in an, extra $10 for supplies.
                            Sleepy
                            Love the Classics!
                              Yes, heavily contaminated/oversprayed vehicles could take well over an hour, but that certainly isn't the typical claybar job.
