just washed and dryed my truck im going to clay truck,do i rewash it after, or go straight to speed glaze
do i rewash car after claying
I've never rewashed after claying. The QD and mf towels work just fine. The clay leaves no residue from itself, and I'm polishing right afterwards anyhow. In my own regimen, rewashing would be a wasted step. (Which is to say, if it works for you, do it; it works for me not to.)
TomAs the light changed from red to green to yellow and back to red again, I sat there thinking about life. Was it nothing more than a bunch of honking and yelling? Sometimes it seemed that way.
I don't wash after claying either. If you left any clay it will be obvious when you wipe the lube off, as the wiping towel will stick. The new Meguairs clay does not leave clay behind like the old version did, and Clay Magic doesn't either.
Besides, if you did leave any clay residue behind, normal washing will not remove it. Best to do spot removal for that, you would need to keep rubbing until the clay comes off and possible use something like MPPC to help.
As long as you use enough lube, there should be no problems leaving clay on the paint.
RamAirV12015 Dodge Charger R/T Scat Pack 392Granite Crystal
2006 GTO Impulse Blue
it did cross my mind not to wash,i thought that the speedglazewould clean any residue left, off the truck,but after reading several people rewashed, i did not want to skip a correct step,next time i will not,i was amazed at how good the clay bar pulls the muck and stuff off the paint,and i was amazed at how smooth speed glaze got the paint to feel,like glass,i posted a couple of pics in the show off section,it a 2003 silvarado,pewter. also the G100 is the workhorse of the detail job,glad i found this site,will do my other cars soon..
Originally posted by ourbail
Hey Mike,what is your 2 cents on this thread.
