I though I would give the absorber a try today. I could use some help because I definitely think I did something wrong. I rinsed it out before use and gave it a light squeeze to remove the majority of the water. Then I went to use it like a chamois and it just stayed in place when I went to pull it across the car, almost like it was glued. What am I going wrong? How do you use the absorber to get it to work well, it there a trick?
The Absorber, How to
The trick to using the Absorber is to use it like a squeegee and drag the water to the edge of the surface, i.e. from the back to the front of the hood. I always sort of wadded up the Absorber or folded it and lifted one edge in my hand and used the other half to wipe the surface. Laying it out flat and allowing the entire towel to make contact with the surface makes it harder to drag. I hope that makes since"I am ready to meet my Maker. Whether my Maker is prepared for the great ordeal of meeting me is another matter." - Sir Winston Churchill
Hi Joe,
I've used the Absorber since around 1988 and can show you how I use it if you like. Tomorrow I'll wash the Blazer and then take a few pictures as this will be easier than typing.
Getting some light rain here now so looks like a wash is on the schedule again tomarrow.Last edited by Lt1Corvette; Jan 11, 2005, 09:46 PM.
Hi Joe,
MikeBrandon
2007 Black Chevy Avalanche
My Albums: Avalanche
I have an Absorber. I like to fold it up two times. I drag it across the surface of the paint and knock off any debris that may have fallen on the paint shortly after washing it. Have to rinse it out often but it works great. My experience is, after wiping it will leave some almost non-existant water spots which quickly disappear.FL
Try a Waffle Weave, and see what you think.My Home Page
2000 Ford Explorer XLT
Alpine CDM-9803, Alpine MRP-F306, Crossfire TEK 35.2, Front Stage: Stock Speakers, JL Audio 10W3D2
Unlike a real leather chamois, the Absorber doesn't make a good squeege. A chamois will glide over the surface, but TA will stick & stutter across the surface as you've discovered.
I usually hold it in the middle and kind of fold it in half. Then I drag the end I have in my fingers from the cowl to the leading edge on the hood, letting the loose part drag along behind. For the roof, I reach out as far as I can and use the same method.
When the majority of the water is off, I wring TA out and loosely 'wad' it up and lightly (no pressure) draw the folds along the body panel. The Absorber is more like a sponge than a chamois, if you put pressure on it while you're trying to dry the car, you will force the absorbed water out and back onto the car.
It WILL pick up a lot of water, but I find it best to wring it out frequently.
For the vertical panels, I just hold the Absorber close to the panel at the top and use my other hand to lightly push TA against the panel, just enough to make contact.
I love the thing, it just took a while for me to find out the right way to use it (pre-internet of course)Don
12/27/2015
"Darth Camaro"
2013 Camaro ... triple black
323 hp V6, 6 speed manual
I use the absorber occasionally on one of my cars. I also folded it in half and just let about half it pull along the surface to minimize drag. But on my 'baby' I swear by the leafblower. If you keep your car waxed...you can blow dry the car in about the same time it takes to dry it with a towel/absorber and you don't have to worry about scratches.
