D151 vs swirlX
  • D151 vs swirlX
    which one is more aggressive? i know D151 is an all-in-one and leaves behind wax, but which has more correcting abilities? ive used D151 a few times so far with great results, but i am going to be detailing my bosses lexus again and was gunna through in a little polishing. she does not want to pay extra, but she has gotten me several new customers so i figured i might as well right! that and if her car looks nicer it should help more too. its an 08 lexus rx350 and i have waxed it several times in the past 2 years, but only wash/clay/wax. it def has a bunch of swirls since she takes it to the "$5 hand wash place on the corner" which i keep yelling at her about lol. i was thinking D151 would also leave a little wax behind so i can then just hit it with m20 and be done....i know D151 will help some with the swirls, and i also know i need to do a test spot to see if either does the job or if i need to step it up a notch, but from a mere aggressive standpoint, which is stronger? o, and i will be using my PC
    Re: D151 vs swirlX
    I haven't used a lot of Swirl X but I have used a lot of 151. The answer to your questions about 151 is it just depends on wich pad you are going to be using. I have removed some pretty serious defects using 151 and cutting pads and finished it out well with polishing pads. By far the best overall combo I have found for me is the green LC pad and my rotary. It has produced some pretty amazing results.
    Tracy
    765-413-7547
    Autobritedetailing@gmail.com
      Re: D151 vs swirlX
      i will be using some soft buff polishing pads and my PC
        Re: D151 vs swirlX
        D151 is more aggressive than Swirlx assuming all variables are kept constant: http://meguiarsonline.com/forums/sho...siveness+order
        Tedrow's Detailing
        845-642-1698
          Re: D151 vs swirlX
          The Aggressiveness Order of SMAT Products - This might surprise you! Super Micro Abrasive Technology = SMAT From left to right, the most aggressive to the least aggressive SMAT products From the most to the least aggressive... M105 Ultra-Cut Compound/M95 Speed Cut Compound = The same in abrading power
          helpful link
            Re: D151 vs swirlX
            that was a great link, thanks! i will give both a try and see how they do, but i will be using them in similar ways, so i would assume the d151 will be my choice
