just used it and its wierd because it dries up to fast and have hard time whipping it off, anyone had the same results here?
using m105
Re: using m105
You aren't the first person to experience that. It does tend to dry up fairly fast. If it was just your first application, put some more on your pad, because a decent amount probably got sucked into the pad to wet it.
Remove swirls my friends.
Re: using m105
M205 should work to get rid of holograms Go ahead and do a test spot to see if the M205 takes them out.. Are these holograms a result of using M105 or are they already on the car. It isn't that unusual to find some hazing after using M105 that should be followed with M205. If they are already on the car from a previous detailer, you should use the least aggressive method of attack. If M205 can take care of them, then go with it!
Re: using m105
Go ahead and do a test spot with M205 and see if it gets them out. If it doesn't step it up to something a little more aggressive then. Remember, ALWAYS do a test spot!
