diluting APC+
  • diluting APC+
    when i dilute my APC+ should i be using bottled or distilled water? or can i just use it from the tap? im pretty sure it doesnt matter, but just asking before i go and do it
    one last question....for 10:1 ratio for light cleaning that means for every 2.5oz of APC+ i use 25oz of water, right? i would do 3oz to 30oz but my bottle is 32oz lol.
    Re: diluting APC+
    I use from the tap, but if you have the option distilled water would be best. Sometimes the minerals in water can interfere with your cleaning results. From streaking, waterspots, etc.
    Matt
      Re: diluting APC+
      I always try to use distilled water. We have very hard tap water.
        Re: diluting APC+
        distilled water is pretty cheap, so i will pick some up thanks!
          Re: diluting APC+
          The only thing I'll use distilled water with is the glass cleaner concentrate, everything else (hyper dressing, apc/apc+, etc.) gets tap water and has worked fine with no negative results all the years I've done so.
