Swirlx - how much hand pressure
  • Swirlx - how much hand pressure
    Not getting the results I would like to see in removing cobweb swirls on a black jeep.
    How much hand pressure should I be using ?
    Re: Swirlx - how much hand pressure
    Try second/third application, that helped me a lot!
      I am using a foam pad and doing a section 12x12 with medium pressure and you cant see a difference. Jeep is a 2008 and has been clayed, polished and waxed about 5 times prior.
      The cobwebs just seem to be getting more noticeable. Should I do multiple applications with light pressure ?
        Doing 2-3 times in one area is not a problem. Can also shrink the work area, work for 30-45 seconds or so.
        Not familiar with that specific paint, something stronger may be needed, if you felt like trying Ultimate Compound.
