I have some classic aluminum wheels that I want to practice on. Something has leached out from behind each of the rivets and blemished the finish. It's possible that I was negligent in cleaning them properly around the rivets. I'm not sure.
They don't have a clearcoat, but if you look close you will see that there are lines cut into the surface of the finish so I can't remove material without making them look horrible.
How do you suggest I attempt to remove these blemishes?
I've never used acid based products. Would something like muriatic acid along with a toothbrush do the trick?
p.s. I don't mind if I ruin them practicing, so I'm open to creative suggestions. Maybe I'll have to spend 100's of hour scraping each line with a dental pick :-)
Bill
