Need some help!
  • Need some help!
    My husband backed into one of those bright yellow poles at the gas station. How do I get the yellow paint off without damaging the car paint?
    Re: Need some help!
    try some ultimate compound and a lot of pressure. If you have a machine it would probably be better. If you have M105 give that a whirl if the UC doesnt work. If all else fails make him get it repainted and sign the divorce papersjk
      Re: Need some help!
      and 1 more thing more than likely it will not come off on the first try it may take several passes.
        Re: Need some help!
        Great! Thanks! I don't have a machine, he was supposed to buff it out before he deployed to Afghanistan but never got around to it. I guess I'll forgive him this time! :0)
          Re: Need some help!
          ok then try some Ultimate compound first probably have to rub pretty hard with a foam or terry applicator. It might take a while, then it might leave some marring or haze/holograms. If you get the paint off and it looks hazy or mares then you may want to try going over it again with some SwirlX. Oh and maybe some pictures would be helpful to us to. If you could post a couple. Let us know how it turns out.
            Re: Need some help!
            How do I post a picture?
              Re: Need some help!
              it tells you how to in the forums. just search it.
                Re: Need some help!
                This link would help out with the picture
                How to upload and insert an image into your posts
                With the issue you have on the car, a picture would help out a lot to see how severe it is but this plan of attach could help out
                -Wash
                -Clay
                -Ultimate Compound or ScratchX 2.0 (using a foam applicator pad)
                -Wax
                These thread would help out with the technique needed, they mention other products but focus on the technique described
                And last! for motivational purposes
                Car Damage - Plan of attack!
                Good luck
                  Re: Need some help!
                  Thank you for your husband's service and your family's sacrifice!
