I just recently began working on my mustang project and decided to detail it while I wait for the motor to arrive. A quick background on it and the problem. I had a buddy paint it about 2 yrs ago. It sat in his paint yard open to the elements as I was overseas. Once I came back I picked up the car and gave it a quick wash only, and it has sat under a covered car porch under a California car cover for the last 6 months. The car was never waxed or detailed. The paint/clear was rough due to being out in the elements for so long before I picked it up. There are some spots that have a very fine amount of over spray, I'm assuming from being out in the yard, and water marks that looked eched into the clear. My goal is the following:
1. remove any over spray
2. make the surface smooth to the touch
3. eliminate the water marks
4. make the paint/clear deep and shiny
I read everything I could and decided to try and follow the advise given on the board. I ordered everything online from Maguiar's and decided to follow the 5 step method. Everything is being done by hand. I first washed and dried the car (gold class wash and drying towel, 2 bucket system). The car was now clean but still rough to the tough. I clay bar 'ed the whole car. The top potions were the roughest as the sides went very quickly. At this point the cars finish looks dull/hazy and the water marks are still present. I then tried SwirlX on a section to test if it would remove the water marks and take some of the dullness away. It did neither (I applied with foam pad and wiped off with MF towel). I decided to try Ult Compound with a new foam pad and MF towel. I still have water marks and the area seems very dull/hazy in the sunlight. I took a few photos (sorry about the quality, Iphone):
At this point I'm not sure what to do next or if this job needs to be done by a professional. I applied some DCPolish to the area photographed to see if it would help at least the hazy/dullness but I don't think it did much. What do you guys think I should do? My last step after the DCP was going to be to wax it with NTX2.0.
Roland
Roland
