How is Megs 205 removal?
  • How is Megs 205 removal?
    I work by hand and have been using megs #80 in the past. I noticed its deficult to remove at times. Is 205 a little more easier to remove?
    Re: How is Megs 205 removal?
    These products should only be difficult to remove if you let them dry, or even start to dry, on the surface. M205 tends to be more forgiving than M80 in this regard, but neither one should be really tough to wipe off. If you find them being so, then apply a small amount of fresh product over the trouble spot and it should reconstitute itself and you can wipe it off right away.
    You might also want to consider Ultimate Compound as a substitute since M205 is actually quite mild. UC offers a lot of cut and is extremely user friendly, even when used by hand.
