I am just about ready to give my car the much needed attention. I plan to detail the exterior of my car. I have been doing a lot of research but I'm just not that certain to pull the trigger and get to work just yet. I need input on how to apply these materials or if i should be using something else.
Most of my concerns are on polishing and how I should do my polisher etc.
Two cars: 02 Acura RSX-S (paint color: nighthawkblack)
03 Lexus IS300 (dark grey)
What I bought: gold class car wash, detailing clay (mild), ultimate quik detailer, M105, M205, NXT GEN tech wax 2.0, APC, Glass Cleaner (professional line). And I have a 7" polisher
Let me know what I'm doing wrong or what I need to be careful about
What I'm planning to do:
Wash: with Gold class car wash
Clay: With detailing clay using the ultimate quik detailer as the lubricant
Polish: Okay my original plan was to go through first with the M105 then go over with the M205. But after researching and reading this article http://www.detailingworld.co.uk/foru...ad.php?t=63859 honestly I got a little scared.
Concerned about using M105 on an Acura
They say typically honda's (same as acura) paint is usually soft. So I was wondering if M105 is way to abrasive for my RSX. If so what should I be using? And have anybody used M105 on a Honda or Acura if so how much paint did it take off.
Paint concern
Typically what is the thickness of average paint what is considered thick, average and thin. I need to know where my concerns lie. Also if a certain area is thin should I avoid it completely? What should I do?
So after claying I was going to polish using M105 unless someone tells me otherwise. Maybe I’m going to use M205 first (I probably will/should).
These are all the pads and pad covers I have
What pads and or pad covers should I use?:
What type of pad should I use to start polishing using M205? Is it okay to use just a MF cover and just keep changing covers or what? Oh and how fast should I go while applying? I was planning on doing one panel at a time (ex: hood, bumper, fender, door, quarter panel etc)
I read about soaking your pad with water first to prep your pad. But then I saw a thread that said if youre using meguiars material you should prep your pad with the ultimate quik detailer. And if so how do I do that? Do I just spray it (if so how much) on the pad then apply M205?
Also does M205 and M105 when applied give a wet water look. Like thick water has been spread across the paint? Shown in this picture below
I don’t know how many pad and or pad covers I will need. Tell me what you guys do. Or if you use pad covers at all? I know about “cleaning your pad on the fly” But wouldn’t I need at least 3 pads 1 for M105 M205 and for the wax? Or could I just change pad covers?
This was going to be my method that I got from the article I mentioned above
Do I buff by hand or do I use the polisher? I would think I just wipe it off by hand right? Also Do I really need to tape a bunch of stuff up? What do you guys do?
After the polishing I would start my waxing.
Wax:
Using a clean cover (or should it be both a clean cover and pad?) Or should I apply with a pad?
The method I would do would be the same as polishing? Someone please confirm.
The interior I was just going to use the APC 10:1 and 4:1 where needed. And do a pressure washer on the engine bay. Do/should I dress the dash, leather seats, and door panel? What should I use? All season dressing (panels) and leather cleaner and conditioner(seats)? Or does APC do the job?
I have did a lot of research. Most of my questions are answered by just doing it. But I want to hear from some experience people to my make my first detailing job a better one with minimal mistakes.
So in summary my main questions and concerns are:
(Detailed answers will be much appreciated it most links and articles/videos I have read/seen don’t address these newb question.) I thank you guys in advance.
Concerned about using M105 on an Acura:
If it’s too strong and if so what should I be using? I want to take the least amount of steps possible but also do it right. Doing it right is more important. Do I have to do the whole car with M105 or just spots I need? Going over with M205 after will make it look all uniform. So I would guess I don’t have to right?
Paint concern
Whats the range of paint thickness. Whats very thick, average, and thin
What areas are usually thin on vehicles and should I avoid them completely?
What covers in what process? I am fairly new on using a polisher. Is one polisher pad good enough and I could just change covers or what?
Paint concern
- Spread or dab polish around the panel with the machine switched off.
- Spread the polish with one or two passes at slow speed (between 2 and 3).
- Begin to work the polish in for three or four passes at medium speed (around 4).
- Thoroughly work the polish until the residue goes clear at high speed (between 5 and 6).
- Buff off residue and assess result.
Wax:
Paint concern
