How do I remove road crud?
  • How do I remove road crud?
    I am having trouble removing road crud, bumps on the surface of the paint where the wheels kicked stuff up. I have tried bug & tar remover first, then clayed but there are still bumps. What should I use... rubbing compound?
    Re: How do I remove road crud?
    Post a pic if you can. I'm not sure of the definition of "road crud"? Sounds like tar to me but a pic will help get you a better responce.
    Professional Automotive Reconditioning Services
    "You scuff it-I buff it!"
      body solvent. or let the bug and tar remover sit for a few minutes. I also heard someone say WD-40 but I would check to make sure it is ok to use on paint first.
        I have used WD-40 to remove tar and it did not hurt the paint. Just keep it away from any rubber, or it will ruin it. I prefer VarSol (paint thinner) to remove road tar. Just clean well with car soap and water after and re-wax.
          i enjoy using this stuff as well...
          Zach Hall
            I have had some good luck with some lightly applied #105 on crud behind wheels....
              Mineral spirits and a bit of elbow grease work wonders! Just be sure to stop once the spot is removed because you're probably removing wax as well. I don't think it'll hurt the clear coat or paint. Others may have insight into this.
              Ray...
              Graphic Designer and detail semi-freak!
                How long did you allow the bug and tar remover to dwell on the paint? It sometimes needs to dwell for a while to work itself in.
                  Just dab some on a rag or a shop towel and rub...it'll break down the tar or whatever you're trying to get rid of and you'll slowly see it disappear.
                  Ray...
