Ultimate Quick Wax question??
  • Ultimate Quick Wax question??
    So the easter bunny (im 17, we keep doin it for the sake of my lil bro and sis) brought me a whole bunch of consumer products...I GUESS THE EASTER BUNNY DONT KNO ABOUT ADS . lol . One of the thing was ultimate quick wax? What do i do with it? Ive never used it??? ive only used UQD...tips and advice! And whats the difference between UQD and UQW?
    Re: Ultimate Quick Wax question??
    UQD is a booster QD. You can use it as often as needed to remove light dust, bird poo, bugs, etc. It has hydrophobic properties, so it helps with water beading. UQW is used to boost your existing wax protection, and should only be used on a 100% clean surface, such as after UQD or after washing. It's awesome - it has amazing water beading and slickness, and really makes the paint pop! Check out this vid for more info:
      The UQW will a spray wax, that you can put on a clean surface to 'boost' the wax that is there. So it leaves a bit more protection then UQD, but does not have the cleaning ability.
      Basically, it is a great product for after future washes.
        Ultimate Quik Wax is a polymer/carnauba blend spray wax that can be used in direct sunlight on a warm surface, and it will not stain vinyl, plastic and rubber trim. It can do a fantastic job of hiding fine swirl marks too.
        It should be used on top of a proper wax application, not in place of it. You can use it every time you wash your car, between those times when you do apply a proper coat of wax. Whether you use after drying the car, or spray it onto each panel while you dry is up to you, but both processes work great. It can noticeably darken medium to dark colors, and it lasts a surprisingly long time for a spray wax. It's hydrophobic polymer properties are pretty amazing too - just take a look at the write up in this thread (scroll down to post #7) and the video from that evening in this thread!
          In between wax. By that I mean that it gives your wax a boost between details. I use after a wash. Either way, it produces outstanding results.
            thanks 4 yalls help! cant wait to try it out!
