what product(s) are good to get stubborn stains of the plastics of your car, ie like when some one leaves a scuff mark with their show on the inside of your door
product to clean interiors
Re: product to clean interiors
APC or APC+ are good general cleaning products. And QID for dusting in between. For more stubborn things, the Magic Erasers have been used by people.
And then soft brushes, MF cloths, etc to apply.2017 Subaru WRX Premium - WR Blue
I've had fantastic luck with APC as well.
Sometimes I find with stubborn stains it's better to spray the cleaner onto an MF or terry towel and rub the stain rather than spraying the stain and wiping it with a dry towel.
Sometimes those scuff marks on interior plastics actually go deep enough to scratch the plastic. In cases like that you might be able to minimize the appearance but you can't fully remove them. To remove a scratch or scrape, you need to level the surrounding material down to the bottom of the scratch. With textured plastics that usually ends up removing the texture from that area as well, leaving a flat and shiny spot.
Hopefully the marks you're dealing with aren't quite that bad.Michael Stoops
