Best No Slag Tire Dressing...
  • Best No Slag Tire Dressing...
    I'm looking for the best, no slag, glossy tire dressing. It drives me crazy to use tire dressings, only to have it spray off the tires and onto the car when driving. I always let the car sit for at least a few hours after application of the dressing, but it doesn't seem to do any good. I also want to make sure that the dressing doesn't damage or "brown" the rubber. I need suggestions from experts.
    Re: Best No Slag Tire Dressing...
    well if your looking for the best dressing that wont sling, it would probably have to be one of the tire gel's like the hot shine gel or endurance gel. however they key to preventing sling on any tire with any dressing is to come back after 10-15 minutes after its dried and give it a final wipe down with a clean rag.
    Addicted
      Thanks for the reply. And how well do the "clean and shine" dressings work? Also, product names would help.
        i dont think ive ever head of that brand name...anyway the products i mentioned in my post were
        Meguiars Hot Shine Tire Gel
        Meguiars Endurance Tire Gell
        Meguiars Endurance High Gloss Tire Gell
        Addicted
          Sorry. I meant the products that spray on and they are supposed to clean and shine the tire.
            oh im not really framiliar with such products...ive always used two seperate products. one to clean the tires, and one to dress. from experience, ive learned 2 seperate products work better than an "all in one" product
            Addicted
              Out of all of the tire dressing's I've ever used, I've only had sling from dressings when either I put too much on or I didn't let it dry enough before I started to drive. As for the tire foam products (the ones that clean and shine), I use those regularly as well, and again, never have a problem as long as I don't start driving right after I've applied it.
                I use soap and water to clean the tires... every once in awhile some Megs APC at 7:1. I don't leave the APC on for very long, perhaps just the time it takes to spray all the tires. I'm not a big fan of removing all the natural protectors from the tire.
                I've used 303 and VinylX in the past as they have good UV protectors. Now I have switched to HyperDressing. I like HD as it can be mixed to great more or less gloss. While it's fairly durable I've read here that Megs All Season Dressing probably lasts a little longer.
                As far as sling... I've read this from many people but I've _never_ had the problem. I use a foam applicator to apply, wait a few hours and then lightly wipe off the excesses. The exception is HD... I can _lightly_ spray this on directly, let it dry and then wipe off the excesses. There is just no need to hose down the tire with product and leave it on. This is probably why is slinging off but it also picks up dirt from the road.
                I really don't like the gels. I think they pick up to much dirt. But that is just my opinion.
                  The way I prevent sling is after I dress the tires. I go back, 20-30 minutes later and remove any excess product. I find doing it this way saves a lot of work down the road.
                  When you mentioned "brown the rubber". Are you referring to the natural action of your tires blooming. I always thought that was the natural characteristics of a tire out gassing. Not from some form of protectorant applied.
                    I know one of my problems is that I really like as glossy a tire as I can get. To that end, I look for dressings that "dry" on the tire, because whenever I wipe after application, I lose the gloss. I also like a dressing that is water soluble so that it's easy to wash off and tends not to build up gunk on the tire. I just tried a gel, so we'll see if it slings.
                    Seems I've had tires that brown and one's that didn't. I assumed it was the dressing that caused it because now there are non-browning dressings. Better ask an expert on this one.
                      The "browning" is from the tire blooming as JA mentions. Basically this help protect the tire from ozone and UV. That is why I don't like to use aggressive cleaners on tires as it removes this protection. I think people tend to use aggressive cleaners mainly because of the excessive dressing that they use. It picks up and bakes on all kinds of crud.
                      But for most people a tires tread will wear out before ozone or UV causes any problems. Heck, if you drive a Focus like I do, the tires will wear out every 20,000 miles.
                        Depending on how you apply a tire dressing, any tire dressing, it can either sling all over the place or not at all. You can make any tire dressing sling, and you can make any tire dressing not sling.
                        Many tires today have textured lines or other graphics on the sidewalls and these can really hold product in - until the tire spins fast enough that physics takes over and the product can no long cling to the surface. The only way to prevent this is to wipe off the excess product after it has been allowed to sit and penetrate for several minutes first. Certainly some products dry more thoroughly than others do, but a heavy application is sort of asking for trouble. Better to apply two thin layers than a single thick one. Best of all, a few minutes after applying any tire dressing come back over the tire with an old (but clean) terry cloth towel and wipe off the excess. Take note of any textured areas on the sidewall that may be trapping excess product.
                        As for any browning you may be seeing, that is not the fault of the tire dressing - any tire dressing, whether a Meguiar's product or someone elses. The browning you're seeing (actually called blooming) is the anti ozonant component built into the tire leaching to the surface in order to protect the sidewall from UV exposure. The level of anti ozonants varies from tire to tire, brand to brand, but all tires have it in them. Regular cleaning of the tire with soap and water and a stiff brush will remove this. If you never actually clean your tires and the blooming starts to build up, it will be loosed and become very noticeable when a solvent based dressing or a cleaner/dressing is applied. But that's just the cleaners releasing it from the surface, not actually causing it to happen.
                          Well, I may have just found the product I was looking for. Yesterday, I tried Eagle One, No Drip Tire Shine Gel. It promises no sling on the spray bottle. I applied it yesterday and drove the car this morning, with no sling appearing on body or fender well. I'm real happy about that. The amount of shine is just what I was looking for...more shine than a satin, but less shine than a gloss. If this gel keeps performing this way, I'll stick with it. I also have a bottle of Zaino Z16 coming, so I'll certainly try it, but at $23 shipped vs about $6 for the gel, I may have to stick with the gel.
                            I am glad you found a product that fits your needs. Good luck with it.
                              Not an expert, but quite a few have responded already. I found a post about browning (which is a good thing and prevents damage). To paraphrase a part of it:
                              "Antiozonant is an ingredient that helps to prevent the exterior rubber surface from cracking, checking, oxidizing, and deteriorating. The rubber is designed in such a way as to constantly work its way to the outside of the tire.... After the antiozonant works its way to the outside of the tire and is exposed to the ozone in the air, it turns brown. The technical term for this effect is blooming."
                              Do a search using this word,
                              Antiozonant
                              or this word,
                              Blooming
                              Also this recent thread,
                              My father-in-law and brother-in-law started using tire foam to dress their tires. They both have different brands of tires but recently they both noticed there are cracks on the outside. Both sets of tires are less than 2 years old. Caused by the products? or no. Are all meguiars products & cleaners, etc... tested for
                              And an excerpt from it...
                              From the FAQ here,
                              http://meguiars.com/faq/index.cfm?fa...ection=_59#_59
                              Most people don't give a lot of thought to their tires except for how they look. Truth be known, your tires are designed to perform under extreme conditions of heat via kinetic energy transfer, high speeds for long periods of time and incredible forces of torque and flexing. That's a lot to ask from a chunk of rubber, inflated with air like a cream filled donut.
                              The science behind the modern rubber formulas used by major tire manufactures today is both complex and interesting. The rubber itself contains and ingredient called Antiozonant.
                              Antiozonant is an ingredient that helps to prevent the exterior rubber surface from cracking, checking, oxidizing, and deteriorating. The rubber is designed in such a way as to constantly work its way to the outside of the tire and as such, continually replenish the exterior surface with fresh antiozonant.
                              This is why you see a brown film on the surface your tires. You can wash your tires with soap or an all-purpose cleaner and remove this film, but in a few weeks, it's back. That's because the antiozonant continually works its way to the outside of the tires every time you drive your car.
                              Thus before applying a dressing you really need to do a thorough job of cleaning the outer surface of the tire to remove any spent antiozonants as well as any previously applied dressing and this will prepare the rubber to accept a fresh application of tire dressing.
                              Meguiar's Tire Dressing Options
                              To maintain your tires and keep them looking sharp with a deep, dark black color, Meguiar's offers six unique tire dressings that treat the rubber with Meguiar's own special conditioning agents as well as patented antiozonants that replenish your tires' original antiozonants and keep your tires looking blacker longer than generic tire dressings and protectants.
                              Special polymers actually penetrate and cure to the surface to form a long lasting barrier-film that protects your tires from inclement weather and exposure to corrosive elements. These include:
                              Hot Shine Tire Spray (Trigger Spray) High gloss formula turns tires a dark black with high shine
                              Hot Shine delivers a high gloss shine in an aerosol or trigger application. Highly water-resistant polymers combined with antiozonant technology keep tires looking blacker longer, while preventing cracking, browning, and premature aging. The high gloss formula gives your tires a “wet-look” with a dark shine.
                              G12032 ..... $6.99
                              32 ounce spray bottle
                              G12024 ..... $6.49
                              24 ounce spray bottle
                              Hot Shine High Gloss Tire Gel
                              Meguiar's® Hot Shine Tire Gel delivers long-lasting, intense shine without annoying overspray, drips or mess! The smooth, concentrated gel application delivers consistent results for even gloss and deep shine. Engineered to reduce sling, the advanced gel formula helps protect against tire fading and cracking to ensure tires always look hot!
                              G12416 ..... $5.99
                              16 ounce bottle
                              Insane Shine Tire Spray
                              G13124 Insane Shine Tire Spray delivers the ultimate in high gloss for tires a deep, dark, "insane wet look." Our spray on and walk away formula delivers a high gloss shine. Our Engineered Synthetic Polymers create a protective barrier that helps prevent browning, cracking and premature aging.
                              G13124 ..... $6.99
                              NXT Generation Insane Shine Tire Coating
                              NXT Generation Insane Shine Tire Coating is the ULTIMATE in high gloss for tires - a deep, dark, insane wet look that is fast and easy just spray and walk away. Engineered Synthetic Polymers (ESP) combined with specially designed antiozonants create a mirror-like shine that prevents browning and premature aging.
                              G13115 ..... $7.59
                              15 ounce aerosol can
                              Hot Shine High Gloss Tire Coating (Aerosol Spray)
                              Hot Shine's high gloss formula gives your tires a wet-look with a dark shine. By combining highly water-resistant polymers with antiozonant technology, Hot Shine keeps your tires looking blacker longer while preventing cracking, browning and premature aging. Available in a 15 oz. aerosol or 24 oz. trigger spray
                              G13815 ..... $6.49
                              Hot Shine Tire Foam
                              G13919 Hot Shine Tire Foam. Our new foam technology breaks clear on the tire (with no milky mess) leaving a deep, black, rich shine. In one easy step, the thick, luxurious foam coats the tire, quickly penetrates, lifts and releases dirt and road grime leaving behind an even, rich shine.
                              G13919 ..... $5.49
                              19 ounce aerosol can
                              Gold Class Endurance Original Formula
                              Endurance® continues to be a favorite among enthusiasts looking for extra long lasting performance with a great look. Our unique formulations stop tires from turning brown and eliminate the mess of overspray, drips, streaks and spotted driveways.
                              G7410 ..... $8.69
                              10 ounce bottle that comes in a box with one applicator
                              Gold Class Endurance High Gloss
                              Endurance® continues to be a favorite among enthusiasts looking for extra long lasting performance with a great look. Our unique formulations stop tires from turning brown and eliminate the mess of overspray, drips, streaks and spotted driveways. 16 oz. High Gloss Gel.
                              G7516 ..... $7.59
                              16 ounce bottle
                              Second, the Sun is a major contributor to drying out and cracking anything, both the visible sun rays, (light), and the invisible sun rays emitted by the sun.
                              Besides the rays then theirs the heat created by the sun to the surface and the environment. The worst areas for drying and cracking are places were the tires are exposed the extreme sun for a majority of the year. For example out here in the desert where I live the sun pretty much deteriorates everything that's not covered up and protected.
                              Goes with the territory.
                              Meguiar's tests all their products to be safe for the surface they are formulated to be used on as long as the products are used according to directions.
                              Success is never final, failure is never fatal. It's courage that counts.
                              by John Wooden
                              '88 Honda
