Windshield sheeting water...
    Re: Windshield sheeting water...
    Hopefully it doesnt go too badly once the RainX wears off, but if you keep up with it should be ok...
    I have had good luck with RainX removing water spots, etc, so it does a little on its own as well.
      Clean the windshield with Stoners Invisible Glass, clay, SIG again, then Klasse AIO.
      BobbyG
        I just clay bared with windsheild and it seems to bead pretty nice. I have a rain sensor for my wipers, and its recommended not to use anything on the windshield if you do, as it can interfere with the rain sensor. So just make sure if any of you have a similar setup its probably best not to put RainX or UQW or anything on.
          I think it should be fine from here. Before even applying the RainX, it started to bead a little, but it had some soap residue on it still as well. The BKF followed by the Vinegar/IPA worked very well! We shall see!
          Thanks for all of the suggestions my fellow MOL'ers!
