M80 + Wool Pad ?
  • M80 + Wool Pad ?
    Hi everyone,
    Have any of you ever used M80 with a wool pad?
    I find that sometimes I need to correct paint where M80 and a polishing pad are not aggressive enough and I am wondering if using M80 and stepping up to a wool pad would be a good alternative?
    Thanks!
    '96 Honda Prelude
    www.vbautodetailing.com
    Re: M80 + Wool Pad ?
    I have never but you can always try. I would be careful you might put in more scratches then you have now.
    Good luck Jim
      Wouldnt want a wool pad at all with a DA, if that is what you are using. Would be better with something like #105.
      Working by rotary would give a bigger variety of options.
        Sorry I should have mentioned I am working with a rotary.
        '96 Honda Prelude
          Have you tried the cutting pad?
            I am not a rotary person, but I think I'd probably still try something like #105, cutting pad, etc before jumping all the way to wool.
              M83, D151, M84, M85, M95 all have less cut that M105 and can be used with a foam pad on the rotary. What happened to the "least aggressive method" on MOL? Don't get me wrong, M105 is GREAT, but also very strong. If you are doing details to remove light swirls, you are going overboard. It would be like washing your dishes with a pressure washer.
                Hi everyone,
                Thanks!
                I have used M80 with a variety of wool pads, from lighter cut polishing wool's all the way up to a 4ply twisted wool pad. You will see an increase in cutting power as well as a decrease in finishing ability as you move of the wool aggressiveness chart.
                Generally speaking it is best to match the product with the pad, so that you get the most efficient use of each. Example- M105 on a wool pad for maximum cutting, M83 on a polishing pad for swirl removal, m82/m205 on a finishing pad for maximum refinement.
                This doesn't mean you cannot use a finishing polish such as M80 with an aggressive pad, it doesn't even mean you shouldn't do it, it just means that it might not be the most efficient method.
                  Why would you go so aggresive, whats wrong with taking the next logical following step .
                  Get some M83 on a polishingpad, if that does not give you the result you're after step up to M84 & a cuttingpad.
                  After that you can refine with M80 & a polishingpad .
                    M80 on a softer polishing wool such as a Lake Country Purple Foamed Wool isn't going to much more aggressive then M83 and a polishing pad. While I agree that it might be the absolute best choice to increase the aggressiveness of polish in this case first, it is not always a viable option.
                    If all you have is M80 and don't want to buy another polish, what is wrong with trying it on a more aggressive pad?
                      I would be very carefull with a combination like that, i would rather buy a more aggresive polish instead of a cuttingpad.
                      Maybe its worth a try , i am gonna test it on a old bodypanel and post the results !
                        I agree, I've removed some pretty mild swirls and scratches with just using #80 and a foam cutting pad then steped down to a polishing pad still using #80 While switching between my G100 and Makita.
                        To me this is the 4 things in my aresonal that I start with first, they teamed together and the right technique and form can do some pretty amazing things! If it don't work after 2 or 3 passes I can always go up to something like UC and grab a polishing pad to try it first before grabbing a cutting pad.
                        Not trying to start anything just telling how I like to use a product to it's full potential! Now I can also understand that if you really don't have time to test and do 2,3 or 4 applications where one might jump up to a more aggressive product (I've done this plenty) but a wool pad can be pretty aggressive and in the long run often times creates more work on yourself removing holograms and such. so trying like others have said #83 or maybe UC using the polishing pad or cutting pad with the rotary should be enough.
                        Like colonelcash stated "using the least aggressive first"
                          Wow, so many responses. I appreciate all the feedback.
                          To be honest, I love working with the foam polishing pads, however I find the foam cutting pads are way too stiff and the last time I used one, it was grabbing the paint way too much, it didn't glide smoothly.
                          So do you think a better option would be to try let's say a polishing pad with M95 or M105?
                          I just want to avoid the foam cutting pads and we must keep in mind that a wool pad remains cooler from what I have seen and a foam cutting pad will generate more heat, which is not a good thing.
                          '96 Honda Prelude
                            I'm not so sure I would be doubting Todd. You obviously have no idea the talent and knowledge this guy possesses. When Todd speaks, everyone should listen. Trust me on this one.
                            Colin
