well some of the cleaner wax for some reason took some of it off but hardley any. if they are etched how would i get rid of them and whats the 105 also water spots on my glass to
To remove water spots by hand get some Ultimate Compound or some Meguiar's rubbing compound. Both can be used by hand but only the liquid should be used by machine.
If the water etching are deep then just be aware that removing them means removing a lot of paint off the surface of your car and the UV protection for the color coat is in the clear coat.
Only fix the problem if the car isn't going to be exposed to the problem causing the water spots again otherwise they will just come back.
I have had water spots on my windshield. I have utilized vinegar and a #5 steel wool which is the finest steel wool you can find. It is referred to steel wool but it actually is a plastic mesh #5 material that I used and with mild rubbing did remove the water spots. The plastic mesh is so fine it will not scratch the glass surface. I keep my car so clean that I have never needed to remove water spots from the paint surface. I always dry the car immediately with Microfiber cloths.
Gliptone sells Spot Check, basically an acid wash. Wash the car in the shade, rinse, leave wet, apply Spot Check on a wash mitt and wash a quarter-panel size area at a time w/ lots of rinsing. Wear hd rubber gloves, don't let the stuff dry on the car, work fast. It leaves the paint absolutely virgin, and super clean, polishing and waxing needed and results are fantastic. Works great also on windows.
If the minerals in the water have literally etched into the paint you'll need a paint cleaner a good bit more aggressive than Cleaner Wax.
Water spots run the gamut from super easy to remove (a little quick detailer and you're done) to almost impossible (rotary buffing with a wool pad and compound). Most are somewhere inbetween these and Ultimate Compound can usually take care of them. You want to work just small areas at a time (about a foot square) and use a bit of elbow grease in the process. Wipe the product off before it dries and inspect the area. If the water spots are gone then continue around the effected areas - if not, then repeat the process until they are gone.
