My Consumer line Product Detailing strategy inquiry
  • #31
    Re: My Consumer line Product Detailing strategy inquiry
    Hi. I've done my first paint detailing attempt with my 1.5 year old majestic red car. I was able to successfully remove the watermarks (which is my only problem). But what I noticed during SwirlX application was that, after using my orbital polisher, I find it hard to remove the remaining scattered substance there. I had to wipe it hard. I was thinking if it's my polisher not really doing the cleaning that much. In the meguiars video, after polishing, you can wipe it easily. What I did for the solution was not to take so long polishing it, then wipe immediately before it dry up. That way the remaining swirlx is not yet hard to remove.
    Is there any other technique in applying it and when to stop and wipe already?
    Many thanks....
    • #32
      You probably figured it out, the SwirlX should be removed before drying.
      You may have worked too big of an area, or worked the product to long, which let it dry out. Try to stay to about a 1 foot square.
      • #33
        What type of towel were you using? A good MF can help.
        • #34
          Hi. Thanks.
          I am actually comparing to other detailers in other shops. When they are polishing with a compound, they don't actually need to wipe with MF towel afterwards. After using a a rotary polisher, the area is almost clean and shiny. No need to wipe off.
          What's the difference with what I'm doing? Is it because of my orbital polisher is too slow to wipe off everything? or SwirlX is lot different from other products?
          • #35
            Hmm.. not sure about the other shops. A rotary should leave some product behind, the last thing you want is to be 'dry buffing', with just the pad spinning on the paint.
            • #36
              Alright. Anyway, I will keep in mind your advice on my next attempt. Thanks very much!
              • #37
                Hi. I tried again a detailing job. Here were the procedures I did:
                1. Wash
                2. Clay
                3. SwirlX with an Oribtal Polisher only
                The car is a 10 year old car. Never been detailed. I started on just a little area. But I did not push through with the job. Because I cant move on to other areas. I find it hard to eliminate the water marks. It seems I need to do a lot more coating I guess. And the white circular spots. I tried several coats of swirlX already. Those spots cant be removed by washing and claying as well. Below are the pics of the defects:
                For your comments on how I can eliminate this plus the hard watermarks. Do I need a rotary polisher and more aggressive compound already?
                • #38
                  That first pic looks like a bit of a divot? They arent rock chips are they? Wont really be able to fix those.
                  • #39
                    What kind of polisher are you using? Is it orbital, dual action or rotary? If it's an orbital, you will probably find that it cannot generate effective paint correction. If you aren't sure which one you have, take a look at these photographs: Machine Photos - DA Polishers - Rotary Buffers - Traditional Orbital Buffers.
                    Check out these threads:
                    Please explain Pros/Cons between Rotary and Orbital Buffers
                    Rotary vs DA Polisher vs Traditional Orbital Buffer
                    It sounds to me that you are not using the right tool for the job. Orbitals should only be used to apply and remove waxes and glazes. I had an orbital and gave it away. If you want to remove swirls, water marks, and scratches, you need to acquire a dual action buffer or rotary buffer. The latter, so I am told, takes a lot of practice to be used safely.
                    --Al Kimel
                    • #40
                      Hi. I was using orbital polisher only as stated above.
                      I actually dont know what are those marks. They are flat and just like water spots. But cant be removed. They maybe overdue stains already due to day-to-day use.
                      Maybe Akimel is correct, i may need a better polisher already here...
                      • #41
                        We tend to agree on this. SwirlX is fairly mild, and an orbital buffer just doesn't have much power at all. Combine the two and you've got a pretty lightweight process that will be easily challenged by issues that a D/A and Ultimate Compound would literally laugh at. In some cases an orbital can do some nice work, but it is easily overwhelmed.
                        • #42
                          thanks. I'll try using D/A polisher.
