hey guys, whats some good foam cannons i can look into that make a really good rich foam that actually sticks on the vehicle long enough to do something
Foam Cannon for pressure washer?
Re: Foam Cannon for pressure washer?
Every Second Counts. Whether it's through our sense of urgency, years of industry experience, vast fleet of delivery vehicles, broad product offering, or personal approach to business relationships, we aim for one goal: to save you time and effort so you can meet your goals.
I think there is more talk on them on autopia, etc... Google should pull up a bunch of threads with a search.
EDIT:
Looks liek Autogeek also sells something, much more expensive though.2017 Subaru WRX Premium - WR Blue
Here are some couple of photos from my last job, might give you an idea
Nilfisk PW + foam lance + CG Maxi Suds II
Skoda Roomster
Pressure Washer
Electric powered high-pressure washer's can be used everywhere that a normal mains pressure hose would be used, but you should take a few precautions with their use. Beware of forcing water into areas where it can't drain, and don't hold the nozzle too close to paint surfaces for as well as impact damage an excess of water pressure could damage paint surface, it can also remove stripes and vinyl graphics.
Be careful when working with the pressure hose nozzle close to the vehicle paintwork, or while working in confined places like engine compartments as it could recoil and cause impact damage, try to keep a three or four foot distance and use the wand at a 45 degree angle They are an ideal tool for the cleaning of fender wells and undercarriage, and for the removal of road salt from these areas.
Power cable extension
Prime Wire & Cable Duplex GFCI (Ground Fault Indicator) Junction Box with 6-Ft. Cord, Model# GF200806 Portable GFCI duplex receptacle detects power leaks and shuts off electricity in less than a second to prevent shock. Test and reset buttons Tough jobsite box with 6-ft. 12/3 SJTW power cord UL listed, meets OSHA standards.
Prime Wire & Cable 50-Ft extension 12/3 Neon Power Cord — Blue, Model# NS514830 Bright NEON extension cord stands out for easy identification. 12 Gauge, SJTW, 3 prong cord features super-flexible vinyl jacket with a cold temperature rating of -31°F. LIGHTED connector indicates when power is on. Cord is water and flame resistant and rated at 15 amps, 125V, 1875 watts, UL listed and meets OSHA standards – Northern Tool
Power cord length (with 5%) voltage drop calculations - http://www.lightshow.cc/explorer/Cal...r_/power_.html
High Pressure Foam Cannon (Foam Lance)
The difference between this and a Gilmour Foamaster II Foam Gun is the water pressure (40 to 90 psi) usually connected to a low pressure garden hose; the HP Foam Lance (Rated Pressure - 2,300 psi) is connected to a high pressure washer (i.e. Karcher Model K5.93M- 1850 PSI, 1.5 GPM, Nilfisk 140.2-9 S Xtra – 2000 PSI, 6.5 GPM (8 litre minute) or similar unit
Also known as foam cannon, foam lance or cam spray unit; the principle behind them is to minimize the amount of paint surface friction necessary to clean the vehicle by pre-soaking it with foam. By allowing the aerated cleaning agent to dwell on the paint surface, giving the surfactants time to reduce the surface tension; so that water /foam can spread and wet the surface.
The principle behind this is to minimize the amount of paint surface friction necessary to clean the vehicle by pre-soaking it with foam. The foam starts loosening the dirt and lubricating the paint surface immediately, thus gentle touch washing with a soft mitt substantially decreases the risk of micro-marring because the paint is covered in a layer of lubrication.
An extract from one of a series of unbiased Detailing Technical Papers © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved.~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ Blog – http://togwt1980.blogspot.com
Some info in my thread I made, as well as some soap comparos. Alter the amount of soap to produce more foam, as well as mess with the +/- dial on the top of it. Currently, I'm blasting out shaving cream
Hello, I am Isaac
