NXT Tech Wax 2.0 DA Process
  • NXT Tech Wax 2.0 DA Process
    So I just finished the M07 and think I am ready for the sealant step. Again, this is my first time doing a car fully using the DA. Here is my plan for this step. If you guys would be so kind as to correct, add, answer the ?'s, or just give any general tips that would be great.
    1. Apply NXT to Black (or Blue?) Lake Country with a bead around the outer edge (about how far will this go before needing to put on more product?).
    2. Apply with Porter Cable on Speed 3 as thinly and evenly as I can.
    3. Do several panels without removing product. Check to see if it is dry.
    4. Take off black pad and switch to a lambswool knitted polishing pad wrapped with an MF bonnet and remove on speed 3 and/or 4 as needed.
    5. Wipe off missed spots with MF by hand.
    6. Wait at least 24 hours and do it again.
    Your advice is appreciated.
    Keith
    "The Dude Abides"
    Re: NXT Tech Wax 2.0 DA Process
    Looking good, Keith. You should be able to wax the entire car before worrying about removal. You'll probably find it best to allow the wax to setup 30+ minutes before removing it. Regarding cure time before the application of a second coat, 12 hours should be sufficient.
    --Al Kimel
      keith, sounds good..what i like to do is start off with nxt 2.0 and then the following day, ill go over the car with QD and then apply M26 for my second coat
      Addicted
        I'd suggest M26 as a second coat too, it looks so great!!
          Please explain the reason to wait 12+ hours before NXT 2nd coat. I have usually done the 2nd coat within an hour or so of the first.
            Optimum time for the polymers to cross link and fully cure. You don't absolutely have to wait this long but many like to.
            Keith, you're plan sounds good, but cover all the painted surfaces of the vehicle and then wait another 30 minutes or so before wiping off. Use the Swipe Test for a final determination of dryness before wipe off.
            A lot of people will apply their wax/sealant to the entire vehicle and then dress the tires, vacuum the interior, dress all the interior vinyl and leather surfaces, clean the windows inside and out, etc. Basically do all those other things while the wax/sealant is curing - it beats the heck out of watching the wax dry. Seriously, that's as much fun as watching grass grow, paint dry or a pot boil. Do something productive while the wax is drying. Clean up and put away all your detailing supplies so you're left standing there with a car covered in hazed wax and a microfiber towel or two to wipe it off. The wax should be completely dry by that time so once you do wipe it off you're done. Literally.
              No hijack intended here...
              I'm sure this has been addressed before, but why is 26 the preferred topping rather than Gold Class?
              Can someone sum up the basic differences in a sentence or two? I'm all hyped up and awaiting the new GC to give it a try...
              "If we knew what we were doing, it wouldn't be called research would it? (Albert Einstein 1879-1955)
              BOB
                Bob, we classify Gold Class Wax as a polish/wax and M26 as a pure wax (meaning it does not contain polishing oils or cleaners - it does not mean that it is 100% wax, don't misinterpret that) and for years it has been the product of choice to top M07 Show Car Glaze. Both are from our Mirror Glaze pro line and are often found close to each other on the shelves of pro products stores. It's just that there's such a long time relationship between the two! Well, that and M26 is pretty fantastic stuff!!
                  Thanks for the clarification, Mike. Does that mean that what little cleaning ability is found in GC would slightly deteriorate the polymer substrate?
                  BOB
                    Ever so slightly, yes. If you're looking to top something like NXT or M21 with a carnauba, M26 is probably a better overall choice due to it's total lack of cleaners. Of course, if you're one of those guys who applies every wax like a cleaner wax (ie, with a lot of power and passion - something you do NOT need to do with a non-cleaner wax) then you're going to be stressing the previously applied product to some extent anyway.
                      BOB
                        I just realized that I hadn't checked back in on this thread. After all your tips, the NXT applications (2 coats) went remarkably smooth. Easiest step so far for sure. Very easy to apply with DA. One thing I found was that I got better performance if I DID NOT "clean on the fly" or swap my pad. Using the same one for a full application actually allowed for the thinnest and best application toward the end of the car. The second coat, a day or so later, was even easier than the first.
                        Removal was insanely simple compared to the previous steps (swirl & polish). I started by using the DA for removal but determined it was pretty much as fast with a hand-held MF and I enjoyed it more seeing the results along the way. I also have a tendency to over-remove with the DA and cause some marring. I recommend hand removal for this product.
                        End result was a very slick feel and deep look. When it is parked in my garage I can use the car door as a mirror to see who is pulling in my driveway!
                        I have moved that car to the secondary garage because I did a quick wax on my staple cars during the holiday (4 additional applications of NXT in the last week). The vet will be back in the primary spot next week and I have to decide if I want to top with M26 or not.
                        As always, thanks for all your help.
                        "The Dude Abides"
                          is the NXT wax a cleaner wax?
                            No, though it does have some very slight cleaners to aid in bonding, as do most consumer-line waxes.
                            Meguiar's cleaner waxes include: Cleaner Wax, ColorX, and M20 Polymer Sealant (as well as a couple of other products).
                            --Al Kimel
                              Must I apply the UQD immediately after the final application of wax, or later?
