How to Remove Holograms ?
  • How to Remove Holograms ?
    Hey guys, i know i read up on how to remove holograms before i just cant remember the method and product to use and i am having a hard time finding the thread again, so i am going to just post this..a week or so ago i did a touch up on a little rock chip on the front fender..after wetsanding the area i used ultimate compound to get rid of the sanding marks...it works extraordinary well..however, today i realized it left a nice hologram in the small area i worked on..how do you get this out again ? id take a picture but its dark out now. so for normal procedure what would you do ?
    please list a few products that will work and i'll see if i have them
    very much appreciated.
    Addicted
    Re: How to Remove Holograms ?
    Did you mean this one???
    Buffer Swirls, Holograms and the Rotary Buffer
    Andy
    Andy M. Moderator
      Thanks Andy,
      I think it might have been..it was such a long time ago..
      I do have #9 Swirl Remover 2.0
      That should work well right ?
      Addicted
        Might, really depends but #9 Swirl Remover 2.0 is a very very mild product. Something I use for finishing purposes not correction, but hey that's me
        Do you have any other product?
          i have fine cut cleaner, ultimate compound, scratchx 2.0, M07, DC2,
          any of those work ?
          Addicted
            Well M07 nor DC2 will work as they are pure polish.
            Fine Cut Cleaner, UC and ScratchX 2.0 will work
            Just try the less aggressive first and go from there. Are you working with a DA?
              I do have a DA...you said UC would work, why would i use UC to clear up these holograms after i used UC and it left the holograms ? or are the holograms results from wetsanding ?
              Addicted
                I just finished going over my entire car with Ultimate Compound and a rotary buffer and needless to say, I ended up with holograms in a few places. I'm in the process of going over the entire car again with Ultimate Compound and a random orbital buffer. It seems to be taking care of the holograms so far, but that all the lights I have to work with are two halogen lamps, one incandescent bulb and one LED hand torch. Surprisingly, the LED hand torch lights up the holograms fairly well if you hold it just above your eyes with the light reflecting directly back to you as you move across the paint. I won't know the full results until the weather clears up and I can get the car out into some sun.
                  The other day I used UC by hand to remove holograms and really small scratches and it did a very nice job (was used on black car) If you used UC on your DA and was left with holograms, try to use Scratch X on your DA which is less aggressive.
                  Slava
                  SK Auto Detailing
                  http://skautodetailing.com
                    Maybe holograms are not caused by UC but by the technique of using the rotary. You can use UC with the polishing pad on a rotary and remove defects and see holograms and you can come back with UC with the DA and a polishing pad and get a perfect defect free finish.
                      well here is the weird thing...i didnt use a rotary..i took out the sanding marks by hand with UC, and it left holograms...weird..it doesnt bother me right now, plus its too cold...once the weather warms up ill hit it with some M205 that iill be getting over xmas break
                      Addicted
