Help please!
  • Help please!
    I've looked around a bit on scratch repair, and seems scratchX may be able to fix these following scratches.
    But I have a quick question, because there isn't much information I can locate on how to properly use scratchX by hand. I know you use a foam applicator pad for about 3-4 coats. Also the scratches are not deep by any means, they are completely smooth, I guess it was just dusty in my area and some jerk walked by w/ a backpack or something.
    But unsure of what people mean by apply w/ 'passion' Also is it recommended I use a clay bar on top of the areas I plan on fixing? And last question, what do you guys recommend to applying after I apply scratchX, am I able to just top off with a sealant or would I have to do glaze/sealant/wax etc?
    The car is a new VW Jetta, normal black, so if anyone has recommendation I am open to hearing them out thank you!
    Re: Help please!
    Passion is just our term for elbow grease. You will have to re apply wax/ sealant to the area.
    If you wanted to you could clay, but it is not necessary.
      Re: Help please!
      Yeah, have to work the product into the paint, not just rub and wipe it on.
        Re: Help please!
          Re: Help please!
          Any quick recommendations on a sealant? I figured I'd use a sealant for the longevity, since I probably don't plan on a full detail for another 5months.
            Re: Help please!
            A sealant that's effective by hand that is, since I don't have a PC yet, plan on getting one after xmas though!
              Re: Help please!
              Look at Nxt 2.0.
                Re: Help please!
                Thanks will look into it.
                  Re: Help please!
                  Definitely let us know how your work goes!
                    Re: Help please!
                    Thanks definitely post after pics, and explain what I did, for feedback and educational purposes.
                      Re: Help please!
                      Oh not bad, NXT2.0 looks promising, only 20bucks online.
                      But do you recommend using some sort of polisher first? Or will clay and scratchX be enough to insure a clean and non-contaminated surface?
                        Re: Help please!
                        As far as all over the car, a good general plan would be:
                        1. Wash
                        2. Clay
                        3. Clean - ScratchX 2.0 the scratches. Then use Cleaner/Wax or ColorX on the whole car.
                        4. Wax - Nxt 2.0
