Gold Class Clear Coat Car Wax or color x wich one is better...
Both products will make it look good. They are different products though. ColorX is a paint cleaner. It has the ability to remove minor swirls and improve the clarity of the paint. I want to stress that it is a very light cleaner. Gold Class is a pure wax. The application is different also. ColorX is something you want to work in a little to use its cleaning ability. Gold Class you wipe on, let have then wipe off.
Re: Gold Class Clear Coat Car Wax or color x wich one is better...
I wouldn't say either is "better." It depends on the surface you are working on and the results you want.
If the car has perfect brand new paint, I'd go with Gold Class. I'd also go with Gold Class if you just used something like SwirlX or ScratchX on the finish. However, if there are minor paint blemishes and you'd like to wax and remove those in the same step, go with ColorX. You can also do ColorX and THEN Gold Class. But don't do Gold Class then ColorX.
Keep in mind that ColorX is a cleaner-wax. This mean's that it has some paint-removal ability (to remove swirls and small scratches). Gold Class is just wax.
We've merged your two identical posts into one so as to avoid any confusion.
As to which of these is the "better" product, that's sort of comparing apples to oranges here. ColorX is by far the better cleaner wax, especially considering Gold Class isn't a cleaner wax at all!!
If you're looking for a really good all in one type product to help you out with some light swirls or oxidation, then ColorX is the more appropriate choice. If, on the other hand, you plan on doing a dedicated paint cleaning and maybe even polish step, and what you really want here is a wax that just offers very good durability with a deep, wet shine, then Gold Class is the appropriate choice.
when using colorx should i use it on a yellow polishing pad? or a finishing pad? on the g110?
I use the polishing pad, it gives more bite (than the finishing pad) on top of the product itself. I've said it many times, Colorx is one of my favorite megs products and a very good one at that!
