which spray wax to use with nxt2.0?
  • which spray wax to use with nxt2.0?
    i was looking through some posts and i read something that said that the nxt spray wax chemically works better with nxt2.0 since it the same line, should i use that instead of UQW for better results and for it to work better chemically?
    Re: which spray wax to use with nxt2.0?
    Go with the Ultimate Quik Wax.
      The products all work fine together.
      And UQW is definately top notch. Wouldnt use anything else (unless they improve it).
        UQW..Nothing is better...
          thanks
            UQW is what you want !
              So I don't have to post a "newb" thread about UQW. Why do you guys like it?
              Experience only looks easy.
              by John Wooden
              '88 Honda
                It works. It goes on easy, lasts a good amount of time, looks good...
                  UQW definitely. Easy to apply. Long lasting, and it looks good.
                    Easy on - easy off !
                    Boosts the existing wax layer !
                    Adds that extra bit of shine and reflection !
                    Smells good !
                    Very little product needed to do the whole car !
                    You can apply it on everything : paint,trims,windows,headlights etc. !
                      Thanks, sounds like my Viagra. Had been using QW because I thought the carnuba would go well with My NXT/M26 combo . I believe I got that idea from some of you, and you wouldn't use the UQW if it defeated that combo. I will give the UQW a try.
                      by John Wooden
                      '88 Honda
