ScratchX or UC?
  • ScratchX or UC?
    Wondering what the paint experts would recommend for gloss black B-pillars ( exterior ); ultimate compound or scratchx; the black is beginning to oxidize. thanks.
    Re: ScratchX or UC?
    Do you have photos? If this is newer car (with a clearcoat), it could not be oxidation but clearcoat failure. How bad is it? Based upon what you wrote, I'd go with U.C. but a photo would still help a lot. However, if what you are talking about is clearcoat failure, then none of the products will help. Here are photos of that.
    -HealthyCivic
    Check out the glossary
      Re: ScratchX or UC?
      We've seen a lot of people have great success on these with UC - just don't use a terry cloth applicator since you'll most likely have to get a bit aggressive and terry cloth can easily haze this surface. Stick to a soft foam wax applicator pad.
        Re: ScratchX or UC?
        To answer 1st question, don't think there are cleared... seems more like a hard enamel that is starting to fade around edges. Thanks, Michael for the tips... will get to some UC.
          Re: ScratchX or UC?
          Many gloss black B pillars are in fact clear coated.
          What vehicle is this on?
            Re: ScratchX or UC?
            Just so we are on the same page... Scratch X 2.0 is just under UC in aggressiveness. Scratch X (old) is way under UC in aggressiveness.
            No good way to answer the question with out photos other then to say start with Scratch X and if that does not work, move up to UC (i.e. start with less aggressive polish and move to more aggressive).
              Re: ScratchX or UC?
              THE PILLARS ARE ON A '99 VW PASSAT; the fading isn't too bad, mostly around the edges. I have used Megs cleaner wax before and lasted a decent amount of time - gone after a couple of washes, will try some of the new scratchx. Thanks all.
