Grit guard
  • Grit guard
    Planning to purchase the grit guard but is the grit guard one size fits all?
    Yes, the Grit Guard fits in any normal 5-gallon bucket.
      Perhaps in addition to the Grit Guard you can try this tip from Rod Kraft:
      Take two 5 gallon buckets
      drill small holes in the bottom of one
      take that bucket and slip inside the other
      Now you have protection against grit contaminating your water
      I bet if you couple that with a Grit Guard you'll have some serious protection!
      my product collection-- New !
      My Detailing Credo
      Treat it like it's the only one in the world.
        I don´t have access to a Grit Guard in Mexico. Is there a way I can build one? Is it plastic or aluminum?
          I don't have one either but I'm getting by just fine with this 2 bucket method I mentioned above.
          My Detailing Credo
            Thank You Bill D.
            I´ll try your method. I guess you have to drill a lot of holes!
              I like the suggestion... but would some of the dirt/sand sit on top of the flat surfaces in between the holes?
              Brandon
              2007 Black Chevy Avalanche
              My Albums: Avalanche
                That´s what I thought, and the only solution is to drill A LOT of holes.
                  Yep, that's exactly what I did
                  My Detailing Credo
                    I don´t mean to hijack this thread, but I have been looking for a grit guard for a long time. When I read this post today I got a lot of ideas, so I went out looking for something similar to use and this is what I found.[IMG]http://archive.meguiarsonline.com
                      I think that may go particularly well with the two bucket-one drilled in the bottom inside the other method
                      My Detailing Credo
