I noticed that there are some really light scratches on my white 2008 F350 with a few that seem slightly deeper. I'm quite certain I know where they have came from...I'll work to eliminate future problems immediately. None the less, I started working them out last night, beginning with some Scratch X and a bunch of effort...no luck. I stepped it up to a rotary, yellow pad and some swirl remover...no luck. I then went to the red cutting pad and swirl remover...with a lot of effort I began to see results, but still a bunch of work. The light scratches were not coming out easily. I then cleaned the pad and used some fine cut cleaner. Much more effective than the swirl remover, but still seems slow. As a Meguiar's fan, I have some medium cut cleaner, but am somewhat reluctant to start with the cutting pad. I'm thinking the yellow pad may be a better starting point with this product choice. Unfortunately, I've heard a lot of good stuff about 105/205, but don't have any yet. What do you guys think? Any other recommendations? I know patience is key and can appreciate this. I can also appreciate doing test sections to see if the product(s) are effective for the application.
Thanks in advance for your help.
