Check out this link if you have time. On page 5 a brief report has been posted about the incredible cutting power of Ultimate Compound using the DA and some specialty pad.
M105 by itself is more aggressive than Ultimate Compound, and a wool pad will also be more aggressive than a cutting pad. Furthermore, in most circumstances a rotary will correct faster than a dual-action polisher. Thus, adding them together in the combinations you suggested would easily make the M105/woo/rotary more aggressive.
That said, from time to time products react in weird ways and sometimes conventional wisdom will be turned upside down.
What are you looking to accomplish? What are you working on?
Thanks the_invisible and Mark Kleis for your advice.
I read the link and this is what I wanted to know - that is '.....UC was much easier to remove.....remove some serious defects, UC also works EXTREMELY well......ease of application and removal of UC .....'.
The thing is that I've been using M105 & M205 on 6-7 cars but I found that it is very challenging to remove. While I know that M105 & M205 are great products but time is money.
I'm looking if UC couple with DA is able to perform close to 95% of M105 & M205, then it would save me 1/4 of the time and I would be happy.
