Should M16 look like this?
Re: Should M16 look like this?
I don't think so. I have a couple cans and they are kinda like candle wax.
AndyKeeping MOL family friendly! If you need help or have a question, don't hesitate to shoot me an email or PM. 101impala@gmail.com
Andy M. Moderator
Looks like the wax was exposed to high (or low) temps.
There are a couple threads about this, you could try heating the wax on the stove to get it back to normal. Some have had success, but it does change the chemical makeup of the wax and is not recommended by Meguiars. Search M16 and it should be pretty recent.
I have a feeling this eBay seller is sending out lots of bad wax and not knowing it.NOTE: Post count does not reflect actual detailing knowledge.
A few other members have had bad wax...
I bought 6 tins and not one is in bad shape.
The double boiler method seems to be a hit, heat slowly and you should be fine if you don't get new ones from the Ebayer.
Good luck.Philippians 2:14 - Do all things without grumbling or questioning,
You should review the threads from people who have heated it up to reform the wax. Keep in mind that high temps can also cause the problem you mentioned... this is essentially what you'd be doing again. The reason why Megs does not recommend it as 1) they don't have control over the process and 2) it's possible that some of the chemicals can evaporate during this process. However, the wax is kept at a low temp... just enough to turn it to liquid. The people who have done this have shown that the wax sets up very nicely afterward and I'd not seen anyone have any problems afterward.
I accidently left my closed tin of m16 exposed to direct sunlight for a couple of hours and the wax completely melted into the same consistency as in your picture !
I mixed it really well into a smooth paste ,flatted the surface with some bakingpaper and then placed it in the refrigerator for a couple of hours.
When i took it out of the fridge it was back in its original form !
