Is it OK to use Cleaner wax or NXT 2.0 on plastic?? A friend of mine has a box truck with the plastic bubble that hangs over the cab..
Waxing plastic??
Re: Waxing plastic??
If the compound didn't work, then the cleaner wax will most likely not work. What compound did you use and with what material did you apply it with? Did you clay bar it first to remove any surface contamination of the rust?
It could be that the rust has actually stained your friend's paint, but let's first see what you used to try to attack it already!
Remove swirls my friends.
Originally posted by Andrew C. View PostIf the compound didn't work, then the cleaner wax will most likely not work. What compound did you use and with what material did you apply it with? Did you clay bar it first to remove any surface contamination of the rust?
