LT Dilution Question
  • LT Dilution Question
    Background: I've been using my Last Touch occasionally diluted 1:1 for some simple paint issues here and there (bird poop, fresh water spots, dust, etc...) as well as for clay lube. As I stated though, I haven't used it a ton because I wash frequently anyway and my car is just a daily driver. A well-kept daily driver, but still a daily driver!
    Anyway, I'm doing a lot more driving now (I commute to school) and I have even less free time so I figure I'm probably going to be using LT more to remove dust and other stuff between washes. The roads that I use to get to school seem to have a little more dust than I'm used to. First question is:
    Questions: How is LT at removing dust after a few days since the past wash? Am I going to create swirls by doing this with a good microfiber? When I say dust, I mean just that - a moderate amount of surface dust but not caked-on or other heavy dirt. My last question is as I said I've been using it 1:1 and had no problem but I haven't been heavily using it so it's hard to tell. Should I just use undiluted formula now that I'm going to be using it more? Thanks.
    -HealthyCivic
    Check out the glossary
    Re: LT Dilution Question
    Well, where the line between light dust and moderate dust is will be hard to say. May have to sacrifice a test panel and see how it goes for a few times?
    And yeah, you can certainly lower the dilution to get more lubrication. I am pretty sure the 1:1 is just for claying really.
      When used at full strength, Last Touch has the most luricity of all the Meguiars Quik Detailers.
        I agree. I usually use Last Touch full strength for a quik detail. Never had a issue with swirling on light to moderate dust.
          Sounds good to me. I just tried it. I just started college and I also work full-time so I literally have 1 day per week sometimes where there's a possibility of me being able to wash my car. Then, if something comes up or I (God forbid) want to rest that day, I can't do it. However, I take good care of my car so often when I wash it, it's not really "dirty," it's more or less covered in what I'd call "road dust." In the past, since I had more time on my hands and I didn't want to create any swirls (which I still don't), I would just wash it. But since I have less time, I think I might start actually putting my Last Touch to more use.
          It's funny too because QDing takes me a while also but it's not really the amount of time that's the factor: It's the fact that I can only wash it in the late afternoon when the sun is on the other side of my house. I just so happen to barely be available at that time now...
          Do you guys have any other QDing tips or stories?
          -HealthyCivic
            You could try Mark Kleis' method on how to wash rinseless using LT + Megs Wash Mitt:
            Ganesa,
            Toyota Vios '05
