Fixing Stained Aluminum: M95 vs M105
  • Fixing Stained Aluminum: M95 vs M105
    A few months back, I was an impatient and decided to use Castrol degreaser to clean my engine bay. Needless to say, I messed up a lot of my polished/brushed aluminum in my engine bay.
    All my brushed/polished aluminum is stained because of the Castrol degreaser. I've used M95 and a terry cloth and buffed most of it out. However, it's a slow, slow process.
    I ran out of M95 now so I need to buy either M95 or M105. What's better for this job? M95 or M105? Is M105 harsher than M95?
    Thanks!
    Last edited by Mike Pennington; Sep 17, 2009, 02:03 PM. Reason: Edited for language
    Double D Garage
    Re: Fixing Stained Aluminum: M95 vs M105
    I'd try M105.
      Thanks.
      Is there a better buffing cloth that I can use? I'm just using a standard terry cloth.
      I won't be able to use a machine because I can't stick a buffer on my intake manifold, intake, radiator, etc...
      Double D Garage
        Well, I use terry on my exhaust.... not sure you'll do much better.
        Metal is tough, so you need some bite.
        Maybe could do a final application with something like the smooth foam applicators just to try for a higher gloss.
          So use a terry cloth to bite and remove the blemishes.
          Smooth foam applicator + M105 or metal polish to give it the gloss?
          Double D Garage
            Well.. its worth trying...
              Great, thanks for replying!
              Double D Garage
                So I got some M105 and terry cloth and it buffed out almost all the damage.
                Observations:
                1.) M105 also polishes out the aluminum. M95 does not. I actually prefer a more brushed aluminum look than polish but its definitely not end of the world.
                2.) M105 is a lot harsher and works faster than M95 on aluminum. I had to be careful how much pressure/rubbing/duration I put on the aluminum as it would be really obvious that a certain part of the aluminum would be shinier than another part.
                Regardless, I still like M105 more than M95 in fixing aluminum. M95 took forever. M105 just works a lot faster.
                Double D Garage
                  M95 is recommended for rotary only. I love it with a Yellow solo wool pad.
                      I've used quite a bit of castrol cleaners on my bay and they were fine. I specificaly used 'Bike Cleaner' and 'Bike Degreaser'. Were you using any of those products?
                        Nope, I'll take a picture of it some day. It's the devil. I hate you Castrol!!
                        Double D Garage
                          I am glad you fixed the problem. Good tip for the rest of us.
                            You might be able to restore the brushed aluminum look with some Unigrit sand paper by sanding in a straight line. I'd practice on a piece of scrap aluminum with different grits until I found the right look
